Originally Posted by Dano1955
Quiet air conditioning in RVs?
As with house-hold air conditioners, noise comes from 4 sources:
compressor
fan to circulate cool air
air flow and fan (if any) to evaporator (outside unit)
cool air flow
You can't do much about the compressor after buying the unit. If it is a major source of noise, rubber mounts may help. But this is typically not the noise you hear.
The fan and the ducts are typically what you hear the most. Back pressure on the fan caused by ducts that are too small or restrict air flow too much will make a fan vibrate. Noise from air flow through the ducts increases exponentially with the speed of the air.
Big, low velocity, low resistance ducts are the key to quiet operation. Those cheap flex ducts with spiral wound wires for support are among the worst for noise. Any duct, especially a round one, with a smooth inside surface will be much quieter than one with a corrugated interior. Increasing the diameter of the duct will help, too.
A caution: low velocity ducts will NOT drive cool air throughout the RV. You will need more vents to get even cooling/heating with low velocity air. It's really a system design thing - and we all know how much RV manufacturers spend on getting quality system design.
Fred W
2014 Rockwood A122 A-frame
And yes, both A/C and heater are noisy in my unit. Both have high velocity fans with small vents because there isn't room to do anything else.
