Old 01-17-2016, 08:07 AM   #1
Issue with Dometic AC unit.
The zone 2 AC unit in my cedar creek 38ck will not cycle off in auto mode, when the desired cooling temperature is reached. Any suggestions?
Lennyg is offline   Reply With Quote
Old 01-19-2016, 02:05 PM   #2
MNtraveler's Avatar
Issue with domestic AC unit.
What happens if you turn the temp up to 90? (I assume you mean the fan does not go off, not that the compressor keeps pumping out cold air, but if it's that please say.)
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 01-19-2016, 05:13 PM   #3
The fan runs and cool air continues to come out if the air is set cooler 70ish degrees. But if I set it to high temps the fan continues to run without blowing cool air.
Old 01-19-2016, 05:17 PM   #4
Flybob's Avatar
Make sure FAN is set to Auto.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-19-2016, 06:26 PM   #5
Yea it was set to auto. so I ended up flipping the breaker off and back on. Now it's working correctly for now. Maybe just dumb luck, hopefully it's not masking a bigger issue.
Old 01-19-2016, 06:51 PM   #6
Todouble's Avatar
Sounds like a relay was stuck. Could be the thermostat or one in the ac itself. See if it happens again.
Todouble is offline   Reply With Quote
Old 01-19-2016, 07:20 PM   #7
If it's a relay issue is that something costly to fix if it keeps happening.
Old 01-19-2016, 07:36 PM   #8
Todouble's Avatar
Nope
Old 01-19-2016, 07:37 PM   #9
Todouble's Avatar
Nope. They're cheap.
dometic
