Old 04-30-2014, 09:31 PM   #1
Jensen 32-inch TV in 2013 Lexington 283GTS
I would like to remove the TV that is mounted over the cab area so I can hook up a HDMI cable, but I can find no access to the mount or however the Tv is held in place. The is absolutely no access around the top or sides or back or through the side cabinets. Any suggestions? Thanks in advance.
2014 Solera 24R
David100 is offline   Reply With Quote
Old 05-01-2014, 04:17 PM   #2
grumpy0374's Avatar
Above and below tv in each corner in the wood trim are wood plugs, look like half round plugs. They will pop out (might have to use a really small screw driver to help) exposing screws that hold the wood trim on. Remove the screws using a #2 square drive tip. The wood trim will than pop off exposing the screws that hold the tv to it's frame. Sounds long, but only takes two minutes.
grumpy
grumpy0374 is offline   Reply With Quote
Old 05-01-2014, 04:21 PM   #3
Thanks I will try that. I am picking it up tomorrow from storage to take a short trip to Mayflower AR. My wife and I are planning several days of disaster relief work for victims of the recent tornadoes in that area.
2014 Solera 24R
2013, lexington
