Old 02-18-2014, 10:41 PM   #1
trikebubble's Avatar
Jensen retrofit cable (to Concertone)
I pulled the Concertone (Model #RV2004DS) and snapped a pic of the main harness on the back end.
Can anyone tell me if the Jenson retrofit cable (#31100133) will attach to this Concertone harness?
I'm looking to replace it with the Jensen AWM975, if this harness works.
If not, and I have to cut and re-wire, then I would probably go with the Jensen AWM968 and get the Bluetooth option.
If the retrofit harness does not fit, has anyone cut and re-wired a Jenson into their trailer and are there any tips or things to look out for to share.
Thanks.
"Anywhere I roam, where I lay my head is home"
Days camped in 2014 - 35
Days camped so far in 2015 - 30
trikebubble is offline   Reply With Quote
Old 02-21-2014, 06:17 PM   #2
Anyone? The CEO is pushing for her new stereo.
Old 02-21-2014, 07:44 PM   #3
bikendan's Avatar
do you have pics of each harness end?
Equalizer WDH
Old 02-22-2014, 10:39 AM   #4
Not really. There are somewhat vague pix on the Jensen site, but they could just be a stock or sample photo. Can't tell for sure if the harness would match, and defiantly can't tell from the pix if the specific wires will match correctly.
Old 04-07-2014, 11:06 AM   #5
I'm going that route myself
I'll be replacing a Concertone ZX700 with a AWM 975 this afternoon. It looks like I'll have to rewire everything. I haven't found any wiring harnesses online. I was hoping to use the wall mount Ipod docking station as well, but it isn't compatible with Jensen.
kndubois is offline   Reply With Quote
Old 04-09-2014, 04:14 PM   #6
I decided to give up on the idea of installing another RV specific dvd/audio system and installed a Pionner car audio/multimedia system, along wit ha pair of new inside Pioneer speakers.
FYI. The speaker wiring diagram on the Concertone manual was different from actual trailer wiring. The inside and outside colored speaker wires were reversed. Just food for thought to actually double check your speaker re-wiring before you seal everything back up.
concertone
