Old 09-23-2014, 12:06 PM   #1
AquaMan's Avatar
Jensen TV. No sound
Noticed last weekend that our Jensen TV had no sound coming out. Checked the audio output, made sure tv speakers were on. Nothing
Switched inputs to a media player via HDMI. Nothing
Used RCA jack inputs. Nothing
Did all of the above with tv speakers off and running through Jensen DVD sound system. Nothing
Yes, the volume was turned up.
It worked the weekend before. Have built in EMS, so no electrical spikes.
Is the tv audio toast or am I missing something? All input devices are working perfect.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 09-23-2014, 12:45 PM   #2
Kaadk's Avatar
Did you pull the DVD and make sure the wire's didn't come loose?
Old 09-23-2014, 12:53 PM   #3
AquaMan's Avatar
I can run my media player through the same RCA's as the tv uses into the sound system, and can produce sound perfectly. So it's not wiring.
Old 09-23-2014, 12:58 PM   #4
Kaadk's Avatar
Ok, so DVD's ok. I'll assume you've tried replacing the cables, so I won't bother suggesting that. I'll also assume you've gone through the TV's setup menus to validate the audio output is still enabled? Might need to double check, just to be sure.
Old 09-23-2014, 01:10 PM   #5
AquaMan's Avatar
Yep, did all that. The only thing I've found that I can change on the tv is "TV speaker on/off". Tried both ways. Nothing. I'm completely stumped aside from audio completely out, but that seems weird to me.
Old 09-23-2014, 01:12 PM   #6
Kaadk's Avatar
Eh, it happens. I'm not sure how old your TV is but I don't put a lot of faith in the ones that come with our trailers. We've gotten 2 seasons out of ours so far and I'm already gearing up to hit the boxing week sales come the holidays to have one on hand in case it dies next year.
