Old 08-11-2013, 08:05 PM   #1
Jensen TV to Jensen AWM970 stereo
I am wanting to play my music channels from Dish network on my Jensen TV thru my ceiling/outdoor speakers using my Jensen AWM970 stereo. Is this possible. Thanks in advance. Steve A. Dagro
sdagro is offline   Reply With Quote
Old 08-11-2013, 08:49 PM   #2
Edge's Avatar
Check to see if you have a cable that runs from your tv to Jensen system. If there is none, plug cable in tv that is marked aux speaker and plug opposite end into the Jensen system marked speaker in. Hope this helps.
2013 SV264 Surveyor Select 10th Anniversary
2011 Toyota Tundra 5.7 V8
Edge is offline   Reply With Quote
Old 08-11-2013, 09:04 PM   #3
I have yellow and red wires running from bottom of TV as well as rear of TV. I assume one is going to outside connection location and the other set goes to Stereo? Is there a certain mode the TV must be in? That's what I can not understand. Another post said AV! mode. But when you change modes I didn't think you could get to your channels. Am I correct? Thanks for the reply. Steve A. Dagro
Old 08-11-2013, 09:13 PM   #4
Edge's Avatar
Those are the RCA cables for the DVD player on the Jensen system.
Old 08-11-2013, 09:37 PM   #5
That Jensen stereo system has only analog audio inputs (red & white RCA plugs). Your TV probably has this same red/white pair. Just connect those up.
If you don't want to have your TV on: I'm going to guess that you have a Vip 211k receiver. Note that there are red/white audio outputs on the back of that receiver as well. You could connect those to the stereo.
Old 08-11-2013, 09:50 PM   #6
Steve
Actually have the 311/322 which is the dual receiver. It is located in living room. Tried putting stereo in aux mode and nothing. May see of there is an aux. speaker port on TV and plug into Aux on front of stereo.
Old 08-11-2013, 10:03 PM   #7
That Sat receiver also has the RCA audio outputs. I suggest that you not assume that there are wires connected to those Aux-inputs on the Jensen stereo unless you've put them there.
Old 08-12-2013, 01:04 PM   #8
Now all I have to do is figure out how to take the stereo out of the hole. Any pointers??
Old 08-12-2013, 01:12 PM   #9
AquaMan's Avatar
There is a frame that surrounds the stereo that simply snaps in place. Remove frame and 4 screws hold the stereo to the cabinet.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 08-12-2013, 02:40 PM   #10
Thanks. I assume there is an audio out port on tv and this need to plug into back of stereo? Satellite receiver is in other room.
