Old 08-08-2012, 11:58 AM   #11
Originally Posted by Triguy View Post
hkreck,
Not sure if you have something like this, but I use these to level. The comfort thing from Dometic that I mentioned is just there to show you what the fridge manufacturer requires. These are the practical way to level ...
I placed one on the front passenger side near the edge to level left/right and one on the other side of the edge of the trailer to level front/rear. They work well for me. I've gotten to where I can use them to tell me how many Lynx levelers to use.
That's what I have and really like them. They work really well when trying to figure how many pads to put under the tires to level the TT.
Len & Cheri is offline   Reply With Quote
Old 08-08-2012, 12:15 PM   #12
hkreck's Avatar
Have you tried putting a fan in the refrigerator to help with circulation?
hkreck is offline   Reply With Quote
Old 08-08-2012, 09:25 PM   #13
Anacortesians
Triguy:
I did the same when we got our MH. I put a 12" torpedo level in the bottom of the fridge and fiddled with the levelling jacks until it was spot-on in both axes. I then attached two stick-on bubble levels, set to show level in each axis, near the driver's seat, where the leveller controls are.
Our leveller system has an auto function, but it really gets carried away and raises the rig to a ridiculous height. My procedure, with DW's help, is to lower the jacks until the pads just touch the ground. I then raise each pair as little as needed to get the rig level with the minimum of jack extension.
If I can't achieve level within my confort zone, I ask for another site or get a refund and go elsewhere. It has only happend once in three seasons and we got a better site.
Frank and Eileen
No longer RVers or FR owners
Old 08-09-2012, 09:09 AM   #14
Triguy's Avatar
Good point, Frank. Its imperative to get it spot on before attaching the bubble levels. I also used your method and spent a lot of time getting the camper level the first time before I stuck on those Hoppy levels. I used a 4' level, checking several places in the camper until just right. Then attached the Hoppys.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-09-2012, 09:40 AM   #15
ironj's Avatar
Originally Posted by sideout1961 View Post
While we are on the subject of refrigerators, Is is normal for the freezer to get cold real quick but the refrigerator to get cold slower? Seems like it takes along time to get cold.
yes...the actual cooling coils are located directly in the freezer...the fridge portion is cooled by a type of "heatsink" fin that get cold from the freezer coils. using a fan on them will help the process.
almost all refrigerators work off of one compressor with cooling coils on the freezer side, and then a fan or other method to transfer cold to the fridge side. Although we did jut get a new fridge for the house that is a dual compressor cooling setup....i cant tell much difference.....they said it would keep the freezer from getting contaminated with smells from the fridge (onion etc)...i suppose it works...lol
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
