Old 06-24-2012, 11:01 AM   #1
Smile Keyless entry
My new Wolf Pup came with a keypad for keyless entry. It did not come with instruction on how to use or how to program the keypad. The dealer does not know. Any information would be appreciated.
Petoskey is offline   Reply With Quote
Old 06-24-2012, 11:03 AM   #2
Don't know which keyless entry you have. Search the web, for the specific brand, and most have manuals and a load of data on them.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-24-2012, 01:15 PM   #3
Keypad Entry
Thanks for the response. The hard part was figuring out the keypad manufacturer. It was a Lippert EA-R03. I was aable to find instructions and program the keypad.
Old 06-24-2012, 01:21 PM   #4
Mine has not worked since day one. I have tried everything and can not get it to work. To be honest with you, I would not have ordered it, it came with a package. I just don't trust it or need it. One day I may see if I can get rid of it.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 06-24-2012, 02:29 PM   #5
Keyless entry
Programming it was not easy. Once I figured out how to program and work it, it appears to be quite good and secure. It operates the deadbolt on the door. The keypad on my trailer can be programmed with up to a 7 digit code which would be difficult to break. On the new trailer, the default code was 1234. After entering the code, press the 1-2 button to unlock or press the 3-4 button to lock. The default code should be changed since it would be easy for others to open the RV.
keyless, keypad
