Old 08-30-2015, 08:54 PM   #1
Killed the power somehow
I had the gen on while running the house AC and making coffee in the coffee maker. Then I turned on the micro and lost power to the AC, outlets, and micro. I flipped the circuit breaker (main one) and still no power. Any ideas for what I can check next? Thanks for any help that's out there.
dNice is offline   Reply With Quote
Old 08-30-2015, 09:00 PM   #2
Try your reset on the genny.Probably a overload on it.
DaveandSue is offline   Reply With Quote
Old 08-31-2015, 01:34 AM   #3
Thurman's Avatar
"dNice" didn't state that the generator quit so we don't know that at this time. We only know that he/she had the A/C on and was making coffee. He/she then added the microwave and lost power to the A/C, some outlets, and the microwave unit. The OP stated that he/she then "flipped" the main breaker and still no power. BUT--the OP did not state that he/she checked any other breakers and/or fuses. My first thought was that one, or more, branch circuit breakers may have tripped. At this time I would recommend that "dNice" check each breaker and each fuse (if so equipped) to assure that they are all in working order. Personally I prefer to pull each fuse and check them with a multi-meter for continuity.
Thurman is offline   Reply With Quote
Old 08-31-2015, 02:40 AM   #4
Just a member
kandl's Avatar
to the forum!
What size/type be your genny? Your RV is...?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge 1500 (the Beast)
kandl is offline   Reply With Quote
Old 08-31-2015, 01:01 PM   #5
Coffee pot and micro could be the same circuit. AC shouldn't have shut down unless the gen shut off though.
What breaker did you check, gen or converter? On the converter there are more breakers, turn them off and back on and see what happens.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 08-31-2015, 01:30 PM   #6
waiter21's Avatar
As others mentioned, check the breakers on your converter.
Depending on your generator, odds are there is a circuit breaker on the genny that you popped.
On my 4k microquite, the breaker is located under the side service cover just to the right of the START/STOP switch.
Look around on your genny. I suspect you popped the breaker.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-31-2015, 03:33 PM   #7
2014 Berkshire 360QL
Check GFCI also. Just hit reset button on each.
Richard D is offline   Reply With Quote
Old 08-31-2015, 07:04 PM   #8
Wow, what a great support community - thank you all for your suggestions!
The RV is a 2016 FR Forester 2501 TSC with an Onan generator. I'm heading over to check the fuses and circuit breaker on the gen right now.
Old 09-01-2015, 09:39 AM   #9
Please let us know what you find.
Jim
George Bernard Shaw
Old 09-02-2015, 11:56 AM   #10
The Onan has a line circuit breaker like the one depicted in a previous posting. It is designed to trip if the generator loads up and starts to slow down below 60 Hz,which can damage your appliances. Too many consumers when not hooked up to shore power will trip the circuit, and it needs to be reset. If your rig has the option to heat your water with either electricity or LP gas, use the LP and either turn off the electric element at the heater or disengage the circuit breaker. That element is a significant consumer.
Timmy Jim is offline   Reply With Quote
led, power
