Old 06-22-2017, 05:22 PM   #1
LCI ONE TOUCH not working properly
I have a 2018 forester and my one touch controller is not allowing me to get to the screen that has the icons for generator, slides, awning, etc. allot shows is my rv. When I touch that it shows the screen with the tabs for control panel, how to, troubleshooting videos, etc. Any help
Is appreciated
lacrawgator is offline   Reply With Quote
Old 06-22-2017, 06:22 PM   #2
Retired and Loving Life!
Alan F's Avatar
Send a message via MSN to Alan F
Try a hard reset. There is a small hole on the bottom front into which you can stick a paper clip. Push it in and reset. See if that helps.
Alan F is offline   Reply With Quote
Old 06-23-2017, 02:35 PM   #3
KayleysMom's Avatar
lacrawgator,
I'm not sure if the LCI One touch is the same as the MyRV system but on our MyRV system if your screen looks like the first picture then you need to run your finger along the white line on the right side from top to bottom and you will then see the "MyRV Control Panel" (second picture). Pressing on that takes us to our icons for generator, lighting, etc.
ID:	142506   Click image for larger version
2017 Forester 2861DS
Chevy Chassis
KayleysMom is offline   Reply With Quote
