I have an LCI system that is supposed to control the interior lights, Awning, Slide and Stabilization jacks. It seems to only control the int. lites and awning. Tried programming and no joy. Wiring seems to be in place. I feel that the Fuse assignments may need to be changed as I have tired everything else. Does anyone have any documentation on how to set up (program) the 8 station LCI controller. LCI's docs say very little about the fuse assignments or the PIN to access the fuse assignments. Any help? Need full programming procedure and PIN # to access the fuse assignments
2016 Forest River Vibe extreme-lite 287
There's not a lot of info on programming the functions, but if you'll bump this tomorrow, I'll see what I can find. Seems like I found something about it a while back.
I assume that you found the receiver.
Gotta go campin!
Yes, I found the LCI receiver. mounted against the outer wall behind drawers, next to the water heater and accessible via the trash bin on the vibe extreme-lite. I could hear clicking when it was activated but as it was mounted against the wall, it sounded like it could have been anywhere on that wall. Thanks for the help.
Problem found! With your suggestion and running out of things to try, I rechecked the fused - all good BUT I noticed some discolored (arcing) burns on the contact tips of two of the fuses. When re-installing the fuses, I forced them in a little further by a little less than 1/4". Apparently he potting used was providing resistance when inserting so the fuses weren't going all the way in. ALL GOOD NOW.
Thanks for coming back and letting us know what you found. I'm sure it'll help someone in the future. It's always good to get feedback on problems and their solutions.
Gotta go campin!
