Originally Posted by snoopy1
Curious about amp draw on my 2017 34qs awning led's, as it must have 75 led's. even at .1 amp that 7.5 amps at the end. Does that sound right? Here's an age old question, does the light in the refer go off after you close the door? same question as when your awning is retracted & you turn on your porch light do the led's come on?
Dave
LED's are very low draw. I just installed a 16' LED strand on our MH. Before I did, I checked that they worked. I used an old AC adaptor that was for an old laptop that I no longer have. It is only 2.6 amps. It fired them right up no problem. I am now using the same AC adaptor to power two 12v 20w lights that are over our bed. It won't light them both at once. They draw 1.5 amps each so three amps total. I have ordered LED replacements.
