OK, so I started a new thread on this for the install. Background information. I have a new 2016 Salem Hemisphere Lite 286RL. Awning LED strip is too Bright, so I bought a remote LED controller like this:
https://www.superbrightleds.com/more...FYWGaQodvxcILw
Had some trouble locating the wiring path for the +/- 12v wiring through the camper. But after removing some panels and investigating, I found it enters the camper in the front awning arm bracket. Inside the camper that is located inside the dresser in the bedroom.
Here is the install: Found the cable entry point inside the dresser:
Once I found the wires (btw nice that they installed a fuse in the bottom of a dresser), I cut them at the junction that was there so I could splice the controller in:
Next I spliced the LED end of the controller to the feed going to the led strip (make sure you use the correct side of the controller, mine was marked):
Next splice the 12v side of the controller:
sand you are complete. Just put the wiring back in the dresser and enjoy your remote!
Hope this helps some others with this mod.
Robb
