Old 03-19-2013, 06:33 PM   #1
Question LED Electrical Noise
Yikes, I just replaced all the lights in my new Viking 16FB with LEDs and now all the radio picks up is static when any of the lights are on. Has anyone else run into this problem, and have you discovered an RFI noise filter that works to reduce the interference?
danking49 is offline   Reply With Quote
Old 03-19-2013, 07:40 PM   #2
TURBS's Avatar
Welcome to the forum !
No noise interference with mine.
Turbs
Old 03-19-2013, 08:03 PM   #3
Did you out a dimmer (PWM) on them by any chance?
Old 03-19-2013, 08:39 PM   #4
RPAspey's Avatar
I'm all led. Yes, I pick up some noise on some lights. Funny thing is that it is not necessarily repeatable. depends on station and which light as it is in proximity to the antenna.
It can be annoying if a good song is playing and someone turns on the light that interferes. just a faint buzz.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-19-2013, 10:23 PM   #5
Nope, no dimmer at all. It is worse with the light closest to the radio; but of course in a 16' box it's a little hard to get very far away ;-) Just an annoying downside to LED lighting (in addition to cost) I hadn't anticipated.
Old 03-19-2013, 11:09 PM   #6
Owner/Operator
RodeoGeorge's Avatar
There is always FM. If the signal is strong enough to reach limiting in the receiver, there should be no LED noise.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 03-19-2013, 11:30 PM   #7
Engineer of Crazy Train
ChooChooMan74's Avatar
We are not supposed to use non approved LEDs on our railroad due to possible RF interference. Most people still do because they are just so much better.
One thing I found out, if you key a portavle radio near an LED, the LED will glow.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-20-2013, 07:50 PM   #8
RPAspey's Avatar
FM - little noise on certain channels with certain lights on.
AM - lots of noise. we don't listen anyway.
I don't know if a filter will work. better grounding might help the radio. I need to properly ground my antenna this spring anyway. I'll report back if that helps.
