Old 06-23-2014, 07:49 PM   #1
mamentt's Avatar
Led replacement strip
Most of my lights are out on the led strip outside. I think the lights are just held there by adhesive and should be easy to replace.
I was going to put up yellow lights with the thoughts that this may reduce some of the bugs at night.
Question, what type of light to use 3528 or 5050??
Thanks to all for the great support on this web site.
mamentt is offline   Reply With Quote
Old 06-24-2014, 09:56 AM   #2
DaveSchwartz's Avatar
Why not get a multicolor strip and have the option?
My 5er came with a white-only strip on the side under the awning but I'm going to put a multicolor out on the awning tube for color and dimming options.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 06-24-2014, 10:12 AM   #3
IT depends what you want to do. the 5050 is a larger chip so with a single color it will be brighter than the 3528. If you are looking for multi-color then the 5050 has all three colors built into one chip so the you get a more uniform color, the 3528 has only one color per chip so you need a red, green, and blue chips to get different colors. with the 3528 you can set the lights up in chase mode where as most 5050 don't do this.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-24-2014, 11:24 AM   #4
im on my second set in a year. its in the shop now getting them replaced under warranty. The sad thing is i dont use them that often and when i do they arent left on very long.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 06-24-2014, 06:22 PM   #5
mamentt's Avatar
Thanks for the information. I found the 3528 lights a little less expensive, and will get them. My lights only lasted about a year. It is cheaper to replace them for me than to take the trailer in for service.
led, replacement
