Old 08-15-2013, 06:35 PM   #11
Jjs2000z's Avatar
Post some pictures
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 08-15-2013, 07:31 PM   #12
Pics of the LED striip
There ya go. You may notice that I've changed out all of the coach lighting with LED's. The original tail lights are from Command Technologies and were an easy conversion with thier upgrade kit.
ID:	37825   Click image for larger version
Radio Dave is offline   Reply With Quote
Old 08-15-2013, 07:33 PM   #13
NCIC105's Avatar
Originally Posted by Radio Dave View Post
I found the Dometic LED strip works great under the awning.
A little silicone rubber around the connectors works great to keep out moisture even in a heavy rain or driving along the highway.
I got mine from Camping World, here in Houston (Katy) Texas and spent less than an hour installing it.
Man-0-Man is that bright stuff!
How did you mount then and get power to them?
NCIC105 is offline   Reply With Quote
Old 08-15-2013, 07:40 PM   #14
LED strip
I ran the connection line down the after mounted upright bracket for the awning. Drilled a hole in the side of the van; comes in the van just above the floor and plugs into the AC outlet 3 inches away, on the wall in the bedrooom.
Old 08-16-2013, 08:34 AM   #15
NYDP77's Avatar
I got mine from a company called HitLights found them online for $40 where some RV retailers wanted nearly $150. All different colors and even a remote. I put mine in a clear light trak at the end of the awning.
DP
2013 Tracer 240 AIR
2014 Silverado 1500
NYDP77 is offline   Reply With Quote
Old 08-16-2013, 11:38 PM   #16
The LED awning light strip is now standard on all Dometic power awnings. It is even set up with its own rocker switch on the control panel. Great feature.
You might check with Dometic and see if you can order directly from them. They might even have some installation suggestions.
Ken
TooLoose - WeTrek
04.5 CTD 2500 Dodge 6spd manual
2014 Flagstaff 8528ckws
elkabong is offline   Reply With Quote
Old 08-17-2013, 12:41 AM   #17
maverick_415's Avatar
I found a 17 foot outdoor LED light strip at Lowe's for $20. It attaches to the awning channel hooks and plugs into the power outlet on the side of the TT.
2013 Forest River Wildcat Maxx 26BHS
2011 Infinity QX56
maverick_415 is offline   Reply With Quote
Old 08-17-2013, 05:30 AM   #18
NCIC105's Avatar
Ken
For 2013 or 14 models?
Old 08-17-2013, 06:49 AM   #19
Capt. Mike's Avatar
2014...but our 2014 Windjammer with Dometic power awning does not have them. When we toured the Rockwood plant two weeks ago, I asked when they started putting them on as standard equipment. June...and ours was build in March. And according to Rockwood, they can't easily be retrofitted.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 08-17-2013, 08:15 AM   #20
stevengb's Avatar
Our 2014 Surveyor Select 305 came with awning LED strip on the awning but we don't use it because its so bright and harsh. Makes me feel like I'm on a Broadway stage or in a surgical procedure room. I guess if I need to dig a splinter out of my sons foot or something I may be glad we have them but other than that they are useless to us.
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
awning, led
