Old 04-25-2012, 09:20 PM   #11
Herk7769's Avatar
Originally Posted by RJHuser View Post
Hi All:
I looked for the specs on the Legend TV also with no luck.
If the TV says 4 amps, and its 12 VDC input, then 48 Watts.
As far as the transformer stating 1.5 amps at 120 VAC (180 Watts) input, 4.58 amps at 12 VDC (55 Watts) output - welcome to the wonderful world of switching power supplies, not very efficient but small and inexpensive to make.
Thats why they recommend not keeping wall warts plugged in when not in use, they still use several to 10's of watts even when not connected to a device (thus the term "parasite" load).
Thank you! I always wondered about that.
HAM CALLSIGN - KC3FFW
Old 04-25-2012, 09:22 PM   #12
Barnman1's Avatar
Onetonford you are the man! I didn't even think about polarity, I just matched the polarity of the output of the 110 xformer to the adapter and bingo Bango bongo the tv will now work with only 12V thank you for your help! Oh and herk when I was talking amps it was all the rating for 12V, I didn't even look at the 110 amps. Now I think I better go get some 5amp fast acting and put in the adapter.
Barnman1 is offline   Reply With Quote
Old 04-25-2012, 09:22 PM   #13
Herk7769's Avatar
Now, back to the OP.
If the unit only pulls 4 amps DC why is it blowing fuses?
Something is still not clicking.
Old 04-25-2012, 09:25 PM   #14
TURBS's Avatar
have you tried plugging anything else into outlet to see if it blows the fuse ?
that would eliminate outlet .
Old 04-25-2012, 09:26 PM   #15
Herk7769's Avatar
Double win!
You fixed your issue and I learned something new.
Old 04-25-2012, 09:31 PM   #16
onetonford's Avatar
Thank You
That was the first thing I did when I made the 12V power cord on Mine you would think the TV manufactures would give you a 12V power cord on a 12V TV???
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 04-25-2012, 10:38 PM   #17
Barnman1's Avatar
Yes I know that is the same thing I thought. Low voltage tv but using 120 with xformer. I also couldn't just get a 12V adapter, I had to get an adapter to connect to the adapter that would fit in the tv. Radio shack had adapters A through Z and being just two pronged they could connect either way. Now in my shame, I am an Electronic Tech, I should have known to check the polarity on something DC before I even connected it.
Old 04-26-2012, 07:06 PM   #18
onetonford's Avatar
The adapter I also bought from radio Shack it also was two prong Right angle I also put a piece of heat shrink over it to hold it from pulling apart.
2011 25 RL Wildcat
