05-26-2016, 03:21 PM
LG Refrigerator--where is the watervalve for ice?
Our new Sandpiper 378FB has a LG refrigerator. We cant get water to the refrigerator to make ice. Where do I search for a water valve? So far, I have found nothing to turn on the water.
05-26-2016, 03:52 PM
Have you looked under the nearest sink?
I don't know if they put the water supply in the valve panel on those units, but you might want to look there as well.
Gotta go campin!
05-26-2016, 11:13 PM
Where is valve for water to ice maker?
It would say valve.....I feel like I am in a cave,sometimes......
We have a 2016 sandpiper 378fb. It has a LG residential refrigerator. After sanitizing water tank...we can't find th valve for water to ice maker. We turned the button on to ice maker. The arm for overfill of ice is down as stated in manual. We found a small valve under the sink...turned it on. Found another below the water filter in the command center..tried it too... Still ice less. Any clue?
05-27-2016, 12:19 PM
I think I posted in another thread from you about the same thing yesterday.
Maybe the mods can merge the two so people can see what's been suggested and what's been tried.
Having said that, have you looked in the manual to see if there's a reset procedure for the maker?
Have you loosened the tubing fitting to see if water is getting to the fridge?
Gotta go campin!
05-27-2016, 09:28 PM
Still no water.il.i
We have done everything in the refrigerator. We do not hear even water coming in to it..thus why we think a valve is closed.
05-28-2016, 09:37 AM
I have a Cedar Creek and the water shut off valve is under the slide that the refrigerator is on.
05-28-2016, 11:35 AM
I had same question on our 2015 model when we first got it. I called FR 5 times and got 5 different answers (all incorrect). I finally just started tearing panels off and traced down the water lines till I found it. It was located behind a door in the pantry that instead of screwing the door to the wall, they had glued it in place. So I had to destroy the door to get to valve. Then replace door and screwed it back in place. You would think, for the price they charge, they would print up an owners manual that explained these things. But then I guess they would have to build them exactly the same, rather than just sticking things where ever they decide to on any particular day.
05-28-2016, 12:05 PM
We have a Sierra 371rebh. The shut off valve is located behind a bottom drawer next to the fridge. You have to remove the drawer to gain access to it.
05-28-2016, 11:30 PM
We have a 2016 Sanibel with a Whirlpool residential refrigerator. I contacted Forest River and they told me they don't hook up the water line because of the freezing liability. They recommended I hire a licensed plumber. Go figure.
05-29-2016, 08:13 AM
Turn on switch
There is a switch on ice maker. You will have to get down and look up at bottom of ice maker to see it. When I turned the ice maker ON , it made ice in an hour or so.
05-29-2016, 05:15 PM
I have the ice maker on....just can't get water to it.
05-30-2016, 08:50 AM
Have you definitively found where the water is fed from? If you have, then I'd remove the tubing from the fitting and see if it's plugged somewhere. I'd even go as far as unhooking both ends and blowing air through it forward and backward.
Gotta go campin!
06-12-2016, 08:47 PM
Global Nomad
Ice Maker Water Turn on
On my Cedar Creek the turn on water switch for the ice maker was under the unit on the refrigerator side by the spare tire. It was a push/pull valve that required some muscle power.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
06-12-2016, 08:50 PM
Yes.
and mine was covered in that blow in gray insulation stuff. I had to tear it off to get to the valve. And I went nuts thinking it was a PULL OUT to make it work type. Nope. It's a PUSH IN to make water flow to refrig. And mine is a bugger to get to. Behind back tire on driver's side, be on your back, and look up.
FROG AR-0019-242
