Old 05-29-2016, 05:15 PM   #11
I have the ice maker on....just can't get water to it.
Thomasnobles is offline   Reply With Quote
Old 05-30-2016, 08:50 AM   #12
Head Rambler
Have you definitively found where the water is fed from? If you have, then I'd remove the tubing from the fitting and see if it's plugged somewhere. I'd even go as far as unhooking both ends and blowing air through it forward and backward.
Gotta go campin!
Old 06-12-2016, 08:47 PM   #13
Global Nomad
Scheinin's Avatar
Ice Maker Water Turn on
On my Cedar Creek the turn on water switch for the ice maker was under the unit on the refrigerator side by the spare tire. It was a push/pull valve that required some muscle power.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 06-12-2016, 08:50 PM   #14
BandJCarm's Avatar
Yes.
and mine was covered in that blow in gray insulation stuff. I had to tear it off to get to the valve. And I went nuts thinking it was a PULL OUT to make it work type. Nope. It's a PUSH IN to make water flow to refrig. And mine is a bugger to get to. Behind back tire on driver's side, be on your back, and look up.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
refrigerator, water
