Old 08-13-2016, 12:35 PM   #11
NMWildcat's Avatar
Thanks!!! Appreciate it.
Scott and Liz - Southern NM
Old 08-13-2016, 12:53 PM   #12
mlwilliams808's Avatar
You can use a small screwdriver to pull the keypad off the panel and unplug it for a few minutes and then plug it back in, this worked for me.
mlwilliams808 is offline   Reply With Quote
Old 08-13-2016, 01:14 PM   #13
fedexflyer's Avatar
Your solenoid is behind the white switch. The item with the large electrical cable that goes to the hydraulic pump. It is used to allow a large electrical surge to the pump, just like in your car, the solenoid is inline from the battery to the starter which has a large electrical draw for a short period as well. It stands to reason that the white switch to the front of the solenoid is the one your looking for.
Like was previously mentioned, you should be able to hook an electric drill to the front of the pump (after disconnecting the electrical from the pump) and run it counter-clockwise to manually bring up the levelers.
Good luck.
USCG Ret
2011 Sportscoach Pathfinder 405FK
2014 Jeep Wrangler Unlimited
fedexflyer is offline   Reply With Quote
Old 08-13-2016, 02:28 PM   #14
Runxtra
That happend to me and it was a "mini breaker" that Forrest River installed. It's in the very front storage compartment on the back wall. Looks like a little buss bar with a tiny reset button on the left side. On my trailer (2015 Silverback 33 ik) they mounted it so close to the outlet on the left that you can't get your finger in there to reset. I need to use a popcicle stick. Mine has tripped several times lately. Tried to attach a pic with iPhone but it said invalid format.
2015 Cedar Creek Silverback 33IK
2015 Ford F-250 Supercrew Diesel
Reese R-16 Slider
Runxtra is offline   Reply With Quote
Old 08-13-2016, 02:32 PM   #15
NMWildcat's Avatar
I would really like to see a pic of that. Sounds like we all need to know what it looks like! Thanks for your info... I'm going outside to see if I can see anything like that. Just for future reference in case I'm in the same boat as the OP!
Old 08-13-2016, 03:07 PM   #16
Witch Doctor's Avatar
Did you pull the plug on the back of the board yet? pull that and wait for 10 sec. and plug it back in. What is the error code you getting ? you have to clear that first by hitting enter. There should also be a breaker next to the pump plus a fuse in a holder on the 12 volt side 12 or 14 ga. Stay plugged in while you do this. If worst comes to worst just bring them up by over riding the valves with a hex driver and drill. Disconnect the pump wire first before you do that. You can also go into auto level again and then after there all down scroll up to auto retract and try it again. Will the board let you go into manual mode? If it will just bring up the rear jack either right or left they work in pairs.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-13-2016, 03:13 PM   #17
NMWildcat's Avatar
This has a reset button in it, don't know if that will help but that's the only reset anything I can find on my system.
Old 08-13-2016, 04:02 PM   #18
Sorry you are havig problems. There is an app for yor phone called mylci please get the app all repair and technical manuals along with pictures are in the app
denville is offline   Reply With Quote
Old 08-13-2016, 04:07 PM   #19
The middle and back leg are on the same solonid
Old 08-13-2016, 05:13 PM   #20
There is a circuit breaker for this system. More like a small button. It is located behind the yellow connector on the left. In the photo .Just push it in.
MBeech is offline   Reply With Quote
