Old 08-18-2016, 02:07 PM   #51
Originally Posted by swbouton View Post
Hello Dalford, I am still unsure about the three knobs that select individual slide operation. Are the knobs you refer to the black knurled dials on this image? I'm reluctant to do anything with them since they seems to be part of the hydraulics.
Thank you, again!
I assume you have these in your RV but I may be wrong. Mine are mounted as shown. I have seen a picture in the past where this IRC manifold with the knobs were just hanging in the basement.
This is in my basement on the drivers side where all the hookup connections are.. I will send a second photo of a closer view but you can see the knobs just above the city water connection sticker. Sorry about sideways pic and not being able to attach 2 photos. Have not learned those tricks yet..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-18-2016, 02:09 PM   #52
alsdas88's Avatar
Link not working?
Don't mean to jump into the OP posting, but for some reason the app store on my iphone will not bring up this link.
Is there another address that can be used?
Thank you.
Originally Posted by denville View Post
Here is the link. myLCI by Lippert Components, Inc.
https://appsto.re/us/8RBRZ.i
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
alsdas88 is offline   Reply With Quote
Old 08-18-2016, 02:09 PM   #53
Close up of IRC Knobs
Here is the closeup..
2016 Siverback 33IK
Old 08-18-2016, 02:13 PM   #54
Thank you.
Try searching on your iPhone app by typing in mylci
2016 Siverback 33IK
Old 08-18-2016, 02:15 PM   #55
alsdas88's Avatar
Hi Dalford,
I tried that, but my phone just brought up today's hot searches without any mention of the app from Lippert.
Thank you for replying so quickly.
Alan
Old 08-18-2016, 02:20 PM   #56
swbouton's Avatar
Perfect. I now know where they are. (One more "user error" to my account.)
Thanks very much for all your help.
2014 Cedar Creek Silverback 33RL
2008 Dodge 3500 6.7L Diesel, Quad Cab, 4x4, dually, long bed.
Steve & Pat, "Diesel" the Boxer, and "Molly" the Scotty
_______________
Bought camper 7/14/16
2016: 9 Nights camping
swbouton is offline   Reply With Quote
Old 08-18-2016, 03:13 PM   #57
Hi Dalford,
I just tried on my iPhone and get the same response. Must not be iPhone compatible. It does work on my iPad though...
2016 Siverback 33IK
Old 08-18-2016, 04:37 PM   #58
I have Mylci on the IPAD and on my Samsung phone. Will try and get my wife's iPhone and see if I can get it loaded
denville is offline   Reply With Quote
Old 08-18-2016, 04:42 PM   #59
swbouton's Avatar
OK, this is how you get the app:
1. Open the "App Store"
2. Touch "Search" on the bottom
3. In the search area type "mylci"
4. Select "mylci". It should be the only entry there.
5. Press "Get"
... and you are done.
_______________
Old 08-19-2016, 10:49 PM   #60
Let me also give you a pointer when using these controls. If you find them hard to turn then back off the hydralic pressure a little. So if the slides are out and you want to close a valve or valves and they are hard to turn then press the top of the white switch for about a second to release some hydralic pressure.
I do this as a rule when I put my slides in or out. You can hear the hydralic motor starting to load down after the last slide is completely extended. Once the last slide is out I push the top of the button for a second just to reduce the pressure. No need to keep that much stress on the Rams and seals.
2016 Siverback 33IK
