Old 08-19-2016, 04:53 PM   #1
Unhappy location of tv splitter
Does any one know where to find the tv splitter on a 2016 xlr thunderbolt 395amp? I have a bad connection some where.
rangerjamesm is offline   Reply With Quote
Old 08-19-2016, 04:57 PM   #2
Do you have the plate for connecting the co-ax for your TV? Mine is behind this plate
Thurman is offline   Reply With Quote
Old 08-19-2016, 05:31 PM   #3
Splitter
There is a wineguard switch in the garage area. The signal is good from the cable coming in from the outside cable. There are four other places to connect a tv. If I bypass the cable and hook directly to a tv it works fine. I am at a camp ground and hooked up to cable tv. There has to be a splitter some where to feed the other four locations?
cat, location
