On my old TT I changed them out. It was really easy.
First pop off/unscrew the cover and measure the diameter of the speaker. Or you can pop off/unscrew the cover and then remove one speaker and measure the diameter of the hole. Removing the speaker is easy, mine were just held in with 2-3 screws per speaker. Unhook the wire connections on the back and the speaker drops right down.
Once you've measured the hole and speaker just find out with the same/similar dimensions and install it in reverse order you just took the old one out. Real easy.
I use Sony speakers for the inside and marine speakers for the outside. if replacing the outside speakers too, caulk around the edges once re-installed to seal it back up. I used pro-flex caulking on the outside and never had a problem in the next year and a half when I traded that TT in for my 5er.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
