04-21-2017, 12:34 AM
Loss of power when hooked to shoreline
I just bought my Hemisphere 300BH 2 months ago. This is my third use of it luckly here at home with the issue im having. I hooked up to shoreline at home and everything was working except for the main A/C. It would come on, run 30 seconds and go off. Everything else in the unit is working. After about 20 minutes I lost power to everything except for the front bedroom AC, the microwave and the bathroom vent fan. I checked all the breakers and no are tripped. I reset them all anyway and no help here. I decided to unplug and hook back up to the truck and everything is working. I plug back into shoreline and everythign is working...for 20 minutes like before. Any ideas?
Thanks!
Frustrated.
04-21-2017, 01:02 AM
What are you plugged into? 15 Amp outlet??
House circuit breaker? GFI outlet?
2014 Ford F-150
2015 Apex Nano 193BHS
2018 Nights Camped: 7
04-21-2017, 01:04 AM
Electrician down the street installed a 50 amp breaker for me. I'm a home inspector but not up to speed on RV's just yet.
04-21-2017, 04:16 AM
2015 F-250 FX4
04-21-2017, 05:00 AM
Sounds like your electrician wired the 50A outlet incorrectly for an RV??.
Good Luck
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
04-21-2017, 01:33 PM
This sounds like a loose connection. As it gets hot, it disconnects (wherever the loose connect is).
I had a similar problem on an older unit, and found a burned wire nut in a main junction box.
-Richard
04-21-2017, 01:41 PM
Thanks everyone. Found out I only had 4 amps at after the converter so located the issue.
04-21-2017, 07:43 PM
What was the issue? Your Fix? This info is helpful to others that may experience a similar issue.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
04-21-2017, 07:45 PM
The converter is bad. Battery is dead. Everything is working with a battery charger in the battery, but I'll have to have the converter replaced. Was only pulling 4 amps inside at the panel that's how I figured it out seeing the fires weren't blown on the converter.
04-21-2017, 07:58 PM
Ret E-9 Anchor-clanker
I would continue to search for proper available amps. Low amps will effect the AC (possible burn it too). Plug a meter in a receptacle, monitor your voltage and your amps.
04-21-2017, 08:08 PM
Thanks!
Andersen hitch
04-21-2017, 10:59 PM
Glad you figured out your issue.
Make sure you get a PI EMS to protect your new converter.
2015 F-250 FX4
04-21-2017, 11:00 PM
Thanks!
04-22-2017, 04:58 PM
I know I am complicating PATRICKSPLACES thread,(and I apologize for that) but can someone tell me what I can click on (in this thread) to allow me to ask a new question and not interfere with PATRIKSPLACES thread ??
04-22-2017, 05:12 PM
You can't click on anything in this thread to start a new thread. If you're on the full site with a browser, click on the sub-forum where you want to start a new thread (in this case, it's Appliances and Electronics - http://www.forestriverforums.com/forums/f113/. Under the word Portal at the top, there's a button New Thread. Click that.
