Old 06-24-2016, 10:54 PM   #1
LandJ's Avatar
Lost several DC circuits
Set up today and all was working well. Came back and water pump, refrigerator and range fan/ light are not working. DC lights and vent fans are working, slides are working.
Any ideas? I have checked disconnect, and have proven DC at the power panel. Not sure what would be common to these circuits.
_________________
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2015 - 36 nights
2016 - 47 nights
LandJ is offline   Reply With Quote
Old 06-25-2016, 12:25 AM   #2
Moderators' Assistant
bikendan's Avatar
Are all the fuses good?
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 06-25-2016, 07:18 AM   #3
LandJ's Avatar
Yes, fuses that I can find are good. I found 2 30 amp fuses on the frame rail, along with a resettable circuit breaker. And all the fuses in the main panel are good.
_________________
John and Linda
2015 - 36 nights
2016 - 47 nights
Old 06-25-2016, 07:20 AM   #4
LandJ's Avatar
Oh my, I just got up and everything is working this morning.
I have no idea what the problem was.
_________________
John and Linda
2015 - 36 nights
2016 - 47 nights
Old 06-25-2016, 11:04 AM   #5
LandJ's Avatar
Looking for any thoughts on this....
_________________
John and Linda
2015 - 36 nights
2016 - 47 nights
Old 06-25-2016, 11:15 AM   #6
clr
If the DC circuits came back as if by some divine intervention I would start looking for a bad or corroded ground. I would clean and redo all the ground associated with the circuits that were effected.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-25-2016, 01:47 PM   #7
DouglasReid's Avatar
X2
I bet they all share that common ground!
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is online now   Reply With Quote
Old 06-25-2016, 04:13 PM   #8
You may have a loose ground in the Main panel
merlbren is offline   Reply With Quote
Old 06-27-2016, 12:14 PM   #9
My ambical cord was pinched and I lost all dc power. I un pinched and wiggled and some came back. I had to replace whole cord.
NorSnrub is offline   Reply With Quote
Old 06-28-2016, 10:50 AM   #10
Head Rambler
Since it came back on, it was most likely a loose connection and since all the DC circuits weren't affected it could be somewhere in the distribution panel itself. I'd pull it and check all the connections tightness. Then check all the ground connections you can find.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
