Do you have LED lights? It's a known problem that a lot of them emit RFI and will interfere with television and radio signals.........but not sure if they cause the buzzing.
If you do have LED lights, I guess the easy test is to make sure they are turned off and see if the buzzing continues.
2011 Flagstaff 831 RLBSS
I DO have LEDs, but I'm sure they're not the issue. The buzz is only there while using AUX, and it occurs with lights off as well.
Is the buzzing coming through only the surround sound speakers, or is it also coming though the TV speakers when raising and lower each separately. Is it all the speakers in the surround sound system or is just one speaker? You have to able to troubleshoot and diagnose where the problem is. I found that FR used really cheap speakers in my Work and Play Toy Hauler and if I crank up the volume they sound terrible and or vibrate.
On my Solera the problem was similar - when playing TV or DVD movie sound through house speakers using in-dash Magnadyne as DVD source and as house sound amp. I used Stinger ground loop isolators ( Stinger SGN20 Ground Loop Isolator:Amazon:Electronics) attached to back of TV. I also had to use an isolator on the composite video feed. Result was quite good. Good luck!
JLeising
2012 Solera "S"
Calif SF Bay Area
I would try it on the audio wires between the DVD player and audio system first. I'm surprised you can have a ground loop with speakers. (They're usually floating, or at least have a common ground.) Maybe that's what the "Noise Filter" part of that thing is doing...killing the low end.
