Old 08-30-2013, 12:26 AM   #1
Jjs2000z's Avatar
Loud buzzing sound from surround sound in tt
New owner of a 2014 Stealth and noticed buzzing sound when I am watching tv or DVD with the surround sound hooked up. Anyone else have this issue?
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 08-30-2013, 03:47 PM   #2
KootenayWC's Avatar
I have it too. Drives me nuts. I think buzzing in the background is usually a grounding issue, but I haven't bothered to investigate yet.
Steve
KootenayWC is offline   Reply With Quote
Old 08-30-2013, 03:58 PM   #3
wmtire's Avatar
Do you have LED lights? It's a known problem that a lot of them emit RFI and will interfere with television and radio signals.........but not sure if they cause the buzzing.
If you do have LED lights, I guess the easy test is to make sure they are turned off and see if the buzzing continues.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 08-30-2013, 04:15 PM   #4
KootenayWC's Avatar
I DO have LEDs, but I'm sure they're not the issue. The buzz is only there while using AUX, and it occurs with lights off as well.
TV: 2012 Ram 1500 Laramie CC
TT: 2012 Wildcat 26FBS
Old 08-31-2013, 01:28 AM   #5
Jjs2000z's Avatar
The led lights have no affect in the buzzing. Still getting the buzzing while watching DVD in my trailer with surround sound on.
2014 stealth 2714
Old 08-31-2013, 06:01 AM   #6
Is the buzzing coming through only the surround sound speakers, or is it also coming though the TV speakers when raising and lower each separately. Is it all the speakers in the surround sound system or is just one speaker? You have to able to troubleshoot and diagnose where the problem is. I found that FR used really cheap speakers in my Work and Play Toy Hauler and if I crank up the volume they sound terrible and or vibrate.
jamesroadking is offline   Reply With Quote
Old 08-31-2013, 10:10 AM   #7
Jjs2000z's Avatar
The buzzing is coming from both of the inside surround sound speakers. The stereo system is the kicker stereo upgrade factory by FR
2014 stealth 2714
Old 08-31-2013, 11:04 AM   #8
fmc
fmc's Avatar
I had that problem with a sound bar.I installed a ground loop isolator. I purchased it on EBay. Solved the problem!
fmc is offline   Reply With Quote
Old 08-31-2013, 01:18 PM   #9
Jjs2000z's Avatar
Fmc how much was it? Where do I install it?
2014 stealth 2714
Old 08-31-2013, 01:35 PM   #10
2012 Solera
On my Solera the problem was similar - when playing TV or DVD movie sound through house speakers using in-dash Magnadyne as DVD source and as house sound amp. I used Stinger ground loop isolators ( Stinger SGN20 Ground Loop Isolator:Amazon:Electronics) attached to back of TV. I also had to use an isolator on the composite video feed. Result was quite good. Good luck!
JLeising
2012 Solera "S"
Calif SF Bay Area
