Old 10-22-2017, 03:01 PM   #1
Loud POP and smoke from fuse box
Hi all-
We plugged in our generator today to recharge and after about an hour we heard a huge pop noise. A few seconds later, we saw smoke coming out of the fuse panel. We unplugged the generator and everything seems to be fine (fuses and breakers ok), but nervous about using the generator again.
Any idea what might have happened?
Thanks for any help!
piperdame is offline   Reply With Quote
Old 10-22-2017, 03:30 PM   #2
Something may have blown in the converter, such as a capacitor. Disconnect a battery cable then run the generator and see if you have lights. If the lights don't work then your converter is fried. Have a fire extinguisher handy just in case.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 10-22-2017, 03:48 PM   #3
Thanks for the quick reply - looks like that is it. We have power to the outlets and microwave when on the generator, but no lights, refrigeration, or heat. However, after about 5 min plugged in to the generator we had another loud pop. Not trying that again...
Think it is safe to use the camper on battery power only? We have panels to charge the battery and would hate to have to cancel our trip.
Old 10-22-2017, 04:30 PM   #4
Sorry to hear that.
Yes, you should be quite safe to run on battery power.
2007 Surveyor SV230
Old 10-23-2017, 08:57 AM   #5
Head Rambler
You can turn the breaker to the converter off and run the generator to power the rest of the 120 volt items.
Gotta go campin!
Old 10-23-2017, 09:03 AM   #6
W5CI's Avatar
You Blew the Capacitors in the Converter, that happened to me while plugged into 50 amp power recently. it burned up lots of stuff. Not Good. You need to find out why your Gen Set blew up your converter. and be prepared to find other things burned up like your Ref and TV.
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2016 Days Camping 50
2017 Days Camping 77
W5CI is offline   Reply With Quote
Old 10-23-2017, 09:08 AM   #7
Flybob's Avatar
Please provide some info on the generator, make, model, size. Turn off breaker for converter and you should be OK running on battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
fuse
