Old 07-25-2012, 12:15 PM   #41
Maintenance
Originally Posted by SpringerPop View Post
When a pro "rambles on", I LISTEN!
Your advice above is SPOT ON!
Too bad that NoAlOx wasn't routinely used until AFTER aluminum wiring fell out of common usage.
It's also too bad that, usually, maintenance people don't periodically tighten the connections on equipment that still has aluminum conductors.
Pop
From your mouth the THE RV PARKS ears, regular maintenance should be preformed at lease quarterly on every pedistal.
Oh ya thats wish full thinking
sorry
HVACretired is offline   Reply With Quote
Old 08-07-2012, 11:00 AM   #42
Still battling with this. Thought for sure it was my cord and was looking around for a deal on a heavier duty one. Then a neighbor moved in next to me and he is having the same problems. Asking the owner to check into it. We will see how far that gets me. Thinking about leaving this camp.
xander is offline   Reply With Quote
Old 08-07-2012, 11:48 AM   #43
Too old to be too smart
SpringerPop's Avatar
Originally Posted by xander View Post
Still battling with this. <snio> Thinking about leaving this camp.
Sometimes, that's about all you can do.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 08-07-2012, 01:57 PM   #44
I have a meter similar to that,when I use it,I add 5 volts ,itis that far off..Get your good volt metert and check it.
Tbonz is offline   Reply With Quote
Old 08-07-2012, 02:22 PM   #45
wmtire's Avatar
For those who aren't handy with a multi-meter, you can go to Home Depot or Amazon and get what is called Kill-A-Watt to plug into a 15 amp 120 volt outlet.
Kill-a-watt is designed to show you much energy an electrical object is using, but it also show the voltage, amps, and watts too. Just another toy you could add to your arsenal.
Amazon.com: P3 International P4400 Kill A Watt Electricity Usage Monitor: Home Improvement
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
voltage, air conditioner
