Old 10-12-2017, 12:50 PM   #1
Exclamation Lowering Freeze Point in Black & Gray Tanks
Has anyone any suggestions for lowering the freeze point in the gray and black tanks, (protective winterizing between dumps)?
We are wintering in Washington and expect some very cold days ahead.
Thanks.
emeth is offline   Reply With Quote
Old 10-12-2017, 01:02 PM   #2
How cold is "very cold"? For some that would mean 25 deg for others -25deg. If the temps are not to get below 20deg nor stay there for very long you could use windshield washer anti freeze for flushing to help protect the black tank. Adding anti freeze to the grey tank does not seem like it would to a lot of good as it would take a lot of anti freeze to not get over diluted and allow freezing anyway.
If you will have full hookups avaialable just leave the grey open and use it as normal.
The best thing would be to dump every evening.
2015 Sunseeker 3010DS
Cargo Pro all aluminum loaded with 1994 Goldwing Trike.
DougW is offline   Reply With Quote
Old 10-12-2017, 01:06 PM   #3
Head Rambler
Does your RV have heated tanks or underbelly? (Not trying to be smart about it, but most RV's sold in that part of the world come with tank/plumbing heaters.)
If so just turn on the heaters or run the furnace a little more than normal.
If neither of those are possible just pour a gallon of RV antifreeze in the tanks.
The best thing would be to go ahead and dump and then add the antifreeze. That way it's also protecting the lines.
Gotta go campin!
Old 10-12-2017, 03:54 PM   #4
Post Lowering Freeze Point in Black & Gray Tanks
The temp we are to expect could be below freezing for varying amounts of time.
Last year, so I am told, went to -20 F.
We do have the 'Arctic Pack' and wonder if it is a good Idea to have empty tanks during the coldest segments with the tank heaters on?
RV Antifreeze would be quite expensive over several months and I am wondering if there is anything else, (we use fabric softener in both the black and Gray tanks), that would lower the freezing point?
Old 10-12-2017, 04:22 PM   #5
Where the heck in Washington state are you going to see -20f other then on top of a mountain
I lved in wester washinto for 8 years and it her then the Mountains saw snow 1 time
My after lives in easter Washington his well pump is in an un insulated shed
Honestly look for a lower elevation near by or put straw bales around and heat the underside
Jmkjr72 is offline   Reply With Quote
Old 10-12-2017, 04:28 PM   #6
Bikersarge's Avatar
I was stationed at Ft. Lewis WA. for 2 years and at that time I don't ever remember it getting below 30 and if it did it was not for very long, they get wet cold winters like Germany.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
Bikersarge is offline   Reply With Quote
Old 10-12-2017, 04:35 PM   #7
Post
Ellensburg, and the temp was most probably caused by wind chill which we do have lost of wind.
It won't really matter as below freezing is still below freezing.
Old 10-12-2017, 04:42 PM   #8
Flybob's Avatar
Some porta-poti companies in very cold areas add water conditioner salt to the holding tanks to lower the freezing point. Inexpensive and easy to obtain.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-12-2017, 05:03 PM   #9
Empty Nesters
You do not want to run the tank heaters (Arctic Pack) with empty tanks. But since you have tank heaters just make sure you have 5-10 gallons in them and turn on the heaters. That is what they are for. Nothing else required to lower the freezing point since you will heat them above freezing.
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
Old 10-12-2017, 05:03 PM   #10
So you are talking about a near record low for that area normal lows are not much below 20 deg
Wind chill can be just as bad because it will cool an exposed pipe down to the ambient air temp faster then no windchill it wont make it any colder just reach that temp faster
Yes here in that he midwest where we do see many subzero days back that he back they do put salt I. Porta johns. But againg just like rv antifreeze it will need that hero be asntifreezedded every time you drain.
The best bet is to put some sort of skirt around and heat under.straw is your best bang and unlike hay has no neutrcional value so it attracts less pests
black, tank
