Old 02-10-2019, 04:39 PM   #1
LPG detector + No Power
I have a 2014 Cardinal. Had to replace my LPG detector. There is no 12volts present. I checked all the fuses, they are good. Are there other fuses elsewhere? Where is the 12 volts supplied from?
Need help?
Thanks.
LivinFull is offline   Reply With Quote
Old 02-10-2019, 08:58 PM   #2
Trailer Park Supervisor
NJKris's Avatar
Just found out that my factory battery disconnect does NOT cut power to detector, which means it is wired directly to the 12 v source. I would check connections closer to battery, to make sure something didn't shake loose.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 02-10-2019, 09:12 PM   #3
Kanadian Kamper
kenandterry's Avatar
All of the toys in my rig that get 12 volts directly from the batteries have their wire direct to the battery with an in-line fuse very near the battery itself.
In my case.....the LPG detector, awning, steps....
You will not typically find their fuses with all the rest.
Ken and Terry
kenandterry is offline   Reply With Quote
power
