Old 10-12-2012, 04:24 PM   #91
Need help with my New 2013? Sunseeker magnadyne DVD player in the dash.
I cannot get a good picture on any of the other TVs.. other than the in-dash screen. It is fuzzy and off center with no sound. I have the AV box in the cabinet set to DVD and all the tvs set to channel 3-0. This worked in the dealership.. doesn't work now.
TroyV is offline   Reply With Quote
Old 10-12-2012, 06:40 PM   #92
Coachmen Adrenaline
Sounds like you are on a digital channel. With the switch box DVD button pressed, use the remote to change the channel to just "3". That should fix it. Send me pm if not and I will try my best to help you fix the problem.
I am on this forum to help as I can, and am in no way the official response of Forest River, Inc.
jamiller45 is offline   Reply With Quote
Old 11-27-2012, 01:07 PM   #93
hi this is lndlord, my gps also reboots. what do i need to do to fix it?
lndlord is offline   Reply With Quote
Old 11-27-2012, 05:43 PM   #94
digger47's Avatar
There is a software fix that should fix the reboot issue. I had my magnadyne replaced because of other issues and the new radio has worked great.
digger47 is offline   Reply With Quote
Old 11-28-2012, 06:38 AM   #95
Send a PM to jamiller45 and he will help you get the software update.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 11-28-2012, 11:39 AM   #96
Coachmen Adrenaline
After Dec 7, you will need to contact BClemens for the info. I will make sure he has it.
Old 11-28-2012, 06:00 PM   #97
jamiller45 - Are you leaving? Hoping not but sounding like that may be the case. You, along with BClemens, have been a great help to the board. Thanks!
paulmlac is offline   Reply With Quote
Old 11-28-2012, 06:17 PM   #98
2012 Solera
X2. I have always found you extremely responsive, helpful, and a pleasure to interact with.
Old 11-28-2012, 06:37 PM   #99
I am a new Sunseeker owner and our GPS had the same issue of rebooting. Thought I would become o member of this forum as I came across it researching solutions. We were going to take it back to the dealership we purchased from, but were unsure if they could fix. Sounds like there is a software fix that we may be able to do ourselves. Let me know also how to get the fix or if we should just go back to the RV Dealership. Thanks.
RVFamily5 is offline   Reply With Quote
Old 11-28-2012, 07:36 PM   #100
Coachmen Adrenaline
Yes. I will be leaving my position as electrical engineer of the class c's. I am pursuing a different position at Forest River. I will remain on the forum and might still be able to help, but I won't have full access to the drawings and specifics I have given some of you. I appreciate the kind words, and will continue to do my best to help out our customers!
dvd, led pad, magnadyne, sirius
