Old 06-22-2014, 09:10 PM   #121
GM
bclemens's Avatar
If you're watching over the air TV you need to set it up for sound. It just doesn't automatically play TV sound. The TV speakers do that.
I post a video of how to do this several times. I'm on my phone now but Maybe some nice soul will post a link.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 06-22-2014, 09:16 PM   #122
GM
bclemens's Avatar
Magnadyne needs to be on AV2.
On the TV go to the menu, tutn tv speakers off. On the audio menu set volume to fixed (not variable). Should play tv sound via surround sound speakers
If not, make sure cables red/whit cables are plugged into audio out of TV.
Old 06-23-2014, 05:41 AM   #123
Regarding USB drive, it may be that the size drive is too big for the Magnadyne to handle. Many car stereos, etc., cannot handle the larger drives. Trying loading some songs on something like a 2G drive and see what happens. Smaller drives conform to the USB 1.0 standard. Larger ones are likely USB 2.0 or above.
(This is just a hunch on my part, but I have run into this on other devices like older digital picture frames, that can't load from larger drives).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 06-23-2014, 08:03 AM   #124
GM
bclemens's Avatar
Ah, here it is.
https://www.facebook.com/photo.php?v...type=3&theater.
Old 12-30-2014, 11:47 AM   #125
While using two different iPod Classics in our 2014 Sunseeker 3010ds there is a constant squealing noise during play. How do you use Bluetooth to pay the iPod? Frustrating to constantly hear squealing during our music. In response to the sub, we had to disconnect ours. It wouldn't stop humming.
Hodie Ho is offline   Reply With Quote
Old 12-30-2014, 01:40 PM   #126
GM
bclemens's Avatar
I don't think the iPod classics are bluetooth compatible.
I think it needs to be an iPhone or an iTouch to use Bluetooth. The rest need to be direct cable connection.
Old 01-01-2015, 09:13 AM   #127
Thanks for the response. The problem is that when the iPod is attached via direct cable there is a squealing noise along with the music. Any idea on how to correct that?
Hodie Ho
Old 01-01-2015, 09:19 AM   #128
Mikegjax's Avatar
Try installing a "ground loop isolator". Cheap and worked to stop the hum on my Magnadyne.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-01-2015, 09:22 AM   #129
What is a ground loop isolator? Where do I get one? How and where do I install it? Sorry, I'm not real savvy with electronic stuff.
Old 01-01-2015, 09:26 AM   #130
Flybob's Avatar
Radio Shack.
Make sure plugs are in all the way.
If you have LED lighting try turning them off.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
dvd, led pad, magnadyne, sirius
