Old 06-12-2012, 06:26 AM   #11
Coachmen Adrenaline
Sparky - what model and chassis do you have?
jamiller45 is offline   Reply With Quote
Old 06-12-2012, 10:42 AM   #12
2012 Solera
New RVer with brand new 2012 Solera. Magnadyne M-4 LCD not behaving well - while navigating, will occasionally "re-boot", going to the "Forest River" screen and re-loading the GPS files. Also, loud hum in audio when watching a DVD (playing on the Magnadyne) on the TV. Was able to stop the hum by disconnecting the red and white audio cables from the Magnadyne to the TV at BOTH ends. Also, when I removed the chassis fuse for the radio - forcing it to run on the house batteries only, the hum was greatly reduced or eliminated (with the red and white wires connected) and the re-booting in nav mode waas less frequent (but still occurs). Any suggestions? Plan to ask dealer in the future - generating my fixit list first.
Old 06-12-2012, 11:07 AM   #13
Coachmen Adrenaline
I got a call this morning about this exact same issue...I will be placing a call into Magnadyne about it and will let you know what I find out. Regarding the other things...The chassis radio fuse has nothing to do with the dash radio. We wire everything directly from the house batteries. The only way the chassis interacts is supplying an ignition signal when using the vehicle. Otherwise the battery disconnect is the same as putting a key in the ignition for the radio. The hum sounds like a minor ground issue that is not too uncommon. The ones you disconnected are used to play the tv through the surround if you wanted to, so they are not really a big loss if you don't need that feature. You could also go to radio shack or something similar and buy a noise suppressor or a ground loop isolator(same thing) and that should pretty much eliminate the issue.
Old 06-12-2012, 03:35 PM   #14
My nav system has also rebooted randomly a few times.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 06-12-2012, 03:47 PM   #15
2012 Solera
Magnadyne re-booting issue
jamiller45 - Thank you for the quick and thoughtful reply!
Of interest, on my vehicle, with the chassis radio fuse in, the radio will work with the house main switch "off". With the fuse removed, the radio will not turn on unless the house main switch is "on". Also, the radio always turns on in "night" or "dim" mode if the engine is running - night or day, chassis fuse in or out. If I turn on the radio before starting the engine, it turns on in "bright" mode, then switches to "dim" when the engine is started. I can then switch the radio to "bright" mode through the touchscreen icon. I suspect this phenomenon is because my vehicle is a California vehicle and is set up to have the low beams "on" automatically whenever the engine is running - so the radio "thinks" it is nighttime. Would like to disable - and switch to "dim" manually when I actually drive at night.
Looking forward to hearing what you find out about the re-boot issue. Again, thanks for the excellent reply!
Old 06-12-2012, 04:38 PM   #16
digger47's Avatar
Angry Still nothing
I held the setup icon for 30 seconds. Nothing happened. I wrote Magnadyne an email, but still no response. The unit states SiriusXM ready, so why would I need a tuner on this model? Not that it matters since I can't even set the time. Oh well, it will have to wait until the vacations are over.
digger47 is offline   Reply With Quote
Old 06-12-2012, 05:28 PM   #17
Sirius XM ready means there is a connection on the back for a little black box to add that feature. (See my previous post) . Car manufacturers also do this. (My sons' Audi and Mazda needed a black box) . The ready part is that once the box is installed the radio itself provides the controls.
Old 06-24-2012, 09:11 PM   #18
Finally got back into the rig (lots of rain --- when? -- weekends, of course!). This time we went east to Drumheller and hung out in the Badlands. Hot and dry. :-) Now, back to the electronics.
Apparently there was some kind of small wiring issue, but I also learned that there is a control for the centre speaker on the M4-LCD, in the Equalizer area -- oddly, if it's set to 'off' it's actually ON and vice-versa. Though I think they actually did me a favour, because as far as I can tell, my ears match the settings on the radio: off is off, on is on.
And, thank you jamiller45 - yes, when the TV is on 3 and the distro box is set to DVD to front TV it does indeed play! AND has surround sound. Now, I've got to hook my movie box up to the distribution unit as one of the AUX inputs and see how it goes. Won't get the surround sound unless I can also manage to get input from the movie box to the Magnadyne. THAT could be a challenge.
Sirius just shows the Sirius icon - no ESN - so suspect no tuner. I'm a bit peeved - and I'll take this higher up the food chain -- I have inside the vehicle a 'welcome to Sirius from Ford' blurb that gives me six free months. With no tuner (if there really is none) I get six free months of silence. Thanks a lot.
iPhone connects via Bluetooth for voice - the quality is, however, poor. No joy with an audio connection via BT. Hardwired via jack to the AV IN is no problem. (Ditto for an iPad.)
Other than that LOVE the 3011DS - it's a treat to drive, easy to fit into, and just a wonderful all-round home-away-from-home.
taxbuster is offline   Reply With Quote
Old 06-25-2012, 04:01 AM   #19
digger47's Avatar
Update
Taxbuster - Glad to hear all is well. I got a call from Magnadyne while on vacation and they confirmed that the tuner is necessary and that the owner must provide. I was told by the tech that I had 6 months free of XM, but nothing in writing.
We walked through my radio issues and though I can access most of the features in a round about way, I can still not set-up the radio. I was told to pull the radio out and remove the power cable. After 5 minutes I plugged it back in and still no change. I was told to have the dealer order a new one. Hopefully I'll have better luck on the next one.
Cheers.
Old 06-25-2012, 06:19 AM   #20
digger47 - sheesh - that's a shame. I guess with a new one at least you'll have the satisfaction of having it work! I'm not happy about the Sirius not included -- everyone talks about it and the brochure says it's there. Personally I believe that is highly misleading. I don't know, though, if that is a Forest River, a Ford or a dealer issue.
I will say that I quite like the DVD-playing ability of the Magnadyne - it pushed the signal through nicely to both TVs (I didn't know my wife had decided to lie down in the bedroom and watch the movie anyway...) and the sound is 'decent' though I may replace the speakers in the end with better ones. Nice to have a remote for it, too.
Good luck and keep us posted on your replacement!
dvd, led pad, magnadyne, sirius
