Old 03-08-2015, 01:50 PM   #21
wmtire's Avatar
Originally Posted by rkymtn57 View Post
Ok Wmtire , Im understanding your posts , thank you ....Yes , she is running the hot water on elect. because she cant go and refill gas bottles but turns it off when not needed. I got ya 30amp only at a time.... I dont think she is using Air Cond. its cool there. Im thinking of all elect. appliances including Refrigerator. Thanks
Im waiting on her.
OK, I was editing my post above with a few more questions to ask her.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-08-2015, 02:03 PM   #22
meganjoe , thank you very much , i appriciate it ! D
rkymtn57 is offline   Reply With Quote
Old 03-08-2015, 02:05 PM   #23
Its raining hard there and she is 81, Ha ha ...Dang !
Old 03-08-2015, 02:10 PM   #24
wmtire's Avatar
Hmmm, we definitely don't want to send her outside to fiddle with anything.
This may be outside the realm of her troubleshooting it.
You wouldn't be lucky enough for her to be near West Monroe, LA would you?
Old 03-08-2015, 02:13 PM   #25
No , its ok she can switch a breaker. Thats all.
Old 03-08-2015, 02:47 PM   #26
Send a message via MSN to Tiggerdad
Ask a manager at the park to assist her. Although they may nmot be electrically included they should be able to check the breakers and fuses.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 03-08-2015, 02:47 PM   #27
dan-nickie's Avatar
If I understand it after reading the entire post and reading between the lines.
1. The inside breaker only pops when she turns on the hair dryer?
2. And you don't think any other appliances are pulling a big load?
3. But the water heater may be on electric also?
Make sure the water heater is not on electric.
ETA: Oh, now I see the breaker won't reset any more.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-08-2015, 02:58 PM   #28
Its on a private lot , she has to use Elect. hot water she cannot carry propane tanks .
She turns it off and on as needed. When she can go outside I will let ya know what happened.
Old 03-08-2015, 03:36 PM   #29
Wmtire , Can I make this permanent rv.....50 amp. ? I guess I would need a new converter ?
Old 03-08-2015, 03:51 PM   #30
BigTJohn's Avatar
50 amp conversion from 30 amp will mean extra wiring and as you mentioned an electrician to do the job correctly. You should not need to do that, however. 30 amp should be more than enough for a 30' rig. The problem could be with the hair dryer itself. If the hair dryer has internal problems, it may be tripping the breaker.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
breaker
