Old 03-08-2015, 04:04 PM   #31
Thank you all very much , I think she overloading the circuit , trying to run a free standing floor heater . She reset all breakers and elect. came back on.
We'll see what else happens , she can also run a extension cord fron the outside pole in to the RV to run the little heater. D
rkymtn57 is offline   Reply With Quote
Old 03-08-2015, 04:04 PM   #32
geotex1's Avatar
Originally Posted by BigTJohn View Post
50 amp conversion from 30 amp will mean extra wiring and as you mentioned an electrician to do the job correctly. You should not need to do that, however. 30 amp should be more than enough for a 30' rig. The problem could be with the hair dryer itself. If the hair dryer has internal problems, it may be tripping the breaker.
A typical 1500W hair dryer is pulling 12.5A, running with an A/C, for instance, and you've taxed all 30A.
geotex1 is offline   Reply With Quote
Old 03-08-2015, 04:18 PM   #33
wmtire's Avatar
She is trying to run an electric heater, with a hair dryer?
As explained, she is limited to 30 amps total.
Another way to look at this is
watts = voltage x amps
or
3600 watts = 120 volts X 30 amps
She cannot run over 3600 watts of things or 30 amps.
a 1500 watt hair dryer and a 1500 watt electric heater are 25 amps together. 1500 watts divided by 120 volts = 12.5 amps
She may even have a 1850 watt hair dryer which draws even more amps.
Her electric water heater element is 1440 watts or 12 amps....when it is on and heating the water.
This isn't counting anything else on 120 volts (microwave, air-conditioner, fridge on electric since you said she has no propane which is 5-8 amps, television, anything plugged into an electric outlet)
She also has a converter that takes 120 volts AC and convert it to power 12 volts DC stuff (lights, fans, furnace, detectors, etc.) The AC amps used by the converter will vary depending on how many 12 volt things she uses at the same time which can be from basically 0-8 amps.
She probably cannot have a hair dryer and electric heater on at the same time. She may also need to turn off the electric water heater element when running the space heater.....as it may overload the main circuit when combined with the amps the converter and refrigerator are drawing in the background.
Just taking some approximations, she is using say 6 amps for the fridge and 3 amps from the converter. If you add the 12.5 amps from the space heater (or more if it's more than 1500 watts), she is using 21.5 amps on those 3 things alone. If the electric water heater element comes on, then you add another 12 amps and you immediately went to 33.5 amps or overload.
She will have to practice energy conversation and learn what can be on...and thus what has to be off at the same time.
Here is some better reading that also has some average appliance amp draws for both 120 volt AC and 12 volt DC:
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-08-2015, 04:21 PM   #34
wmtire's Avatar
But if I understand, she has reset all the subcircuit breakers and currently has 120 volt power? Is this correct?
Old 03-08-2015, 04:32 PM   #35
dan-nickie's Avatar
I fugured there had to something else on that was not known.
Glad she got it.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-08-2015, 04:40 PM   #36
geotex1's Avatar
Not necessarily. It's fairly common for the 20A and 30A receptacles to be on the same feed so there's only 30A available.
Have you considered setting your mother up with a propane service since it's on a lot? Have a much larger free-standing tank delivered and filled on a schedule. May work out cheaper (and safer) in the long-run for her to be able to use the propane furnace and heat hot water this way since I'd assume the electric is metered. Just a suggestion.
Old 03-08-2015, 04:51 PM   #37
Yes , Im thinking about a propane tank. Thank you.
Old 03-08-2015, 04:52 PM   #38
Yes , Wmtire she now has 120.
Old 03-08-2015, 04:57 PM   #39
wmtire's Avatar
Excellent, I just edited my previous post #33 to add more information.
It may help you educate her somewhat on what she should turn off....or not turn on at the same time.
Old 03-08-2015, 05:00 PM   #40
Flybob's Avatar
A 30A RV outlet and a 20A household outlet in your pedestal does not mean you can run 50A from the pedestal. It generally means you have two ways to access power but only 30A to work with.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
breaker
