Old 03-09-2015, 09:16 AM   #51
Again this a private lot off of a utility pole. Thanks.
rkymtn57 is offline   Reply With Quote
Old 03-09-2015, 10:30 AM   #52
Originally Posted by Flybob View Post
This is correct, but up stream from the pedestal is a breaker that serves several pedestals and that breaker is generally chosen to be 30A times the number of breakers serviced. If no one else is in sites adjacent to you or they are not using power, you may have more than 30 A. by using both outlets. If all others on your circuit are at 30A or above you will not.
Not sure I follow.. Whatever size wire is run to the pedestal has to be protected by the appropriate sized breaker.. I'm envisioning a Distribution Panel with a bunch of 50 Amp breakers and a separate feed to each pedestal...
I could be wrong but I doubt they daisy chain the pedestal power as they would have to run a very large, expensive wire..
Joe
meganjoe is offline   Reply With Quote
Old 03-09-2015, 11:11 AM   #53
Originally Posted by meganjoe View Post
l...
Joe
At an older RV Park in FL where we stayed for 5 years did run a dozen sites off the same power cable. I know because when everyone used AC, our PI would shut down our camper due to low voltage brownout @ 102V. Park had service dig up and replace old cables sitting in damp soil. Situation improved but still not what it should have been. Each site was 30A and some were 50A.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 03-09-2015, 02:16 PM   #54
Now AC is on but it will not recharge 12v system and CM alarm sounds continueusly..
Old 03-09-2015, 02:21 PM   #55
wmtire's Avatar
Could be bad battery, bad converter, disconnect switch.
I think I remember you stating that you just had a converter installed. They could have some wiring loose or perhaps blew the reverse polarity fuses (very common occurrence) to the converter somehow either in the installation of the converter or battery wires.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-09-2015, 02:50 PM   #56
could be a bad cb
wire1946 is offline   Reply With Quote
Old 03-09-2015, 04:14 PM   #57
Try turning off the circuit breaker that controls the converter/charger, and then back on. Perhaps it has tripped and is not receiving power.
Old 03-09-2015, 04:17 PM   #58
wmtire where would the reverse polarity fuses be located ?
Old 03-09-2015, 04:37 PM   #59
wmtire's Avatar
This recent thread may help:
No 12 volt or hvac
As explained in the thread link above, the reverse polarity fuses may be in the electrical distribution box where the circuit breakers are, or could be on the face of the converter itself.
Old 03-09-2015, 05:01 PM   #60
Witch Doctor's Avatar
I had the electrician wire a 120 box for elect. yard tools.
Instead of everyone guessing, just call the electrician back and tell him you do not have power to everything and have him check it. If it's reversed polarity it is easy fix he just switches two wires. Did he check it out that everything worked before he left? People can guess here forever, I think everything has been covered already. Time to call him being your not there. How long ago did he install the box?.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
breaker
