Old 07-19-2016, 10:40 AM   #21
wmtire's Avatar
Originally Posted by cv ILL View Post
I called the dealer, he checked another Wolf Pup in his stock, it had 30 main, 20 AC.
I have replaced the breakers, he will take care of the cost.
The wire to the main appears to be #10 , the AC wire #12.
I have attached before and after photos for others. Guess its something I, and others should look at, although probably not a common problem.
Thanks to all that gave input.
Thanks so much for the pics, as this may help others down the line. I thought maybe a dealer could have "borrowed" some breakers, but now think this is really a factory mess up. Glad you were handy enough to fix it yourself, as many would not be.... and kudos to the dealer for stepping up also.
I'm surprised you didn't trip a 15 amp incorrect main breaker even without the A/C.
2011 Flagstaff 831 RLBSS
Materialism: buying things we donít need with money we donít have to impress people that donít matter.
Old 07-19-2016, 10:58 AM   #22
Witch Doctor's Avatar
Your very welcome, thanks for getting back to us who try to help on this FRF. Most will not let us know the out come. Your problems should be over now, but I have 30 amp to, and I do run the W/H on propane because you will still trip the 30 amp with the A/C on and if your W/H is on electric...Have a GREAT SUMMER...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
breaker
