Old 07-16-2016, 03:25 PM   #1
Main breaker trips with AC
My first long trip. Hot day, and the AC unit trips off the main breaker, 15A.
Frig is also running. Each have their own 15A breaker, but the main trips. Seems to me that the main should be 30A, (or something higher than 15A) to match the power plug and campground connection.
Retired 2015
2016 Wolf Pup 16BHS / 2009 GMC Acadia, Red
cv ILL is offline   Reply With Quote
Old 07-16-2016, 05:24 PM   #2
fonzie's Avatar
The main should be 30 amps, make sure your water heater is on propane only and all should be fine.....
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-16-2016, 05:40 PM   #3
Flybob's Avatar
X2 main should be 30A.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-16-2016, 05:43 PM   #4
Witch Doctor's Avatar
You should have a 30amp breaker for your main are you sure it's 15 amp. 120 volt? If it's 15 amp go buy a 30 amp and put it in, what size A/C do you have. Most A/C will pull about 17 amps FLA with the fan running on a hot day. Is this a new unit, you might also want to pick up a 20 amp for your A/C at the same time? PS: Your RV refer should only pull like 6 amps on electric. I'll attach a list of appliances amps.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-16-2016, 06:48 PM   #5
Thanks, that's what I thought, it should be 30A main for 120v. Guess I need to visit the dealer when I get home.
Retired 2015
Old 07-16-2016, 11:29 PM   #6
I wouldn't. It be quicker for you just to purchase a new one and replace the incorrect one yourself. Most dealerships take their sweet time to do warranty work. Can you afford to wait weeks for the factory to approve the warranty repair?
Skyliner is offline   Reply With Quote
Old 07-17-2016, 08:45 AM   #7
WFD
Like Fonzie said...turn your water heater to propane in hot weather with the a/c running all day and you will be fine. Mine trips on those hot days with a/c running, fridge running and if I try to run water heater on electric.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-17-2016, 01:20 PM   #8
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Don't go replacing a 15 Amp breaker with a 30 Amp, unless the wiring is 10 gauge or more. You'll open the door to bigger headaches if you do.
Grampa Jim is offline   Reply With Quote
Old 07-17-2016, 02:04 PM   #9
DouglasReid's Avatar
x2, you can burn the thing to the ground with you in it if you hook up a 30 amp breaker to anything less than 10 gauge wire. The breaker is there to protect the wiring, not the appliances. It also protects you since it is designed to prevent fires caused by overheated wiring.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 07-17-2016, 02:11 PM   #10
fonzie's Avatar
X3, if your plug is 30 amps, make sure the wiring between the breaker panel and your outside male plug-in is rated for 30 amps eg: # 10 awg
Fonzie
breaker
