Old 07-21-2014, 06:35 PM   #11
I had my daughter (a welder) take two bolts and weld them to a piece of stainless steel (thin stuff, 3 mil.) flat stock at the spacing of the exterior bracket. The flat stock metal can be attached to any set by drilling holes where ever needed. The bolt heads slide into the slots of the external bracket. Costs about $30.00 to make if you buy the materials. Daughter had the metal, I had the bolts. Cost a me a hug.
I use it every weekend. I just bought a cheep set at Wal-mart for the external TV. Works good when the game is on and the wife wants to watch the food network.
Netcomdude is offline   Reply With Quote
Old 11-25-2014, 09:21 AM   #12
OK everyone, I have found part numbers and ordered them and here they are.
TV mounting bracket - scissor 10-16349A
TV mount (exterior) 10-16285A
I went through my local RV dealer to order the parts. I was in luck when I talked to them. The parts manager had just got done doing a month research on getting them parts for another customer. These are the Forest River part numbers.
ID:	66831   Click image for larger version
ID:	66832   Click image for larger version
willy13fl is offline   Reply With Quote
Old 11-25-2014, 09:47 AM   #13
Infractee
Nice work! Those are the pieces in our unit, we have two sets plus the plate in the first pic on the outside. They work well and the travel lock is tight.
RhoZeta is offline   Reply With Quote
Old 11-25-2014, 01:45 PM   #14
I had gone to my dealer mid-summer to get these. The interesting part is I wanted to just get an extra wall mounting bracket, but a plastic bushing on my scissor bracket broke after inspection. The dealer covered the scissor bracket under warranty so when they ordered the new scissor bracket I asked them to order me an extra wall mount. When the parts arrived the scissor bracket came with another wall mount bracket plus the extra one I ordered. So I'm guessing there is a P/N for the assembly as well. Unfortunately, I threw the paperwork away so not sure what the P/N's are. I never actually gave the dealer any P/N's, they looked into it and did there own homework and called me back the next day.
2014 Rockwood Roo 19
adellicson is offline   Reply With Quote
Old 11-25-2014, 02:19 PM   #15
khocke's Avatar
Slightly off topic as these are different than what's already mounted on your rig. I'm adding a bedroom TV and plan on using it outside as well. Found these plastic ones on eBay, in black and white. I do like yours better, but I don't need the articulated piece.
http://stores.ebay.com/pawinternatio...p2047675.l2563
khocke is offline   Reply With Quote
Old 11-25-2014, 02:50 PM   #16
Those are pretty decent too. I have to say that the combination of the scissor bracket and the wall mount is nice though. Your brackets seem as though they may not be as secure in holding the TV in place while underway, but you could always just take the TV off the wall just to be safe. The wall mount bracket locks in pretty securely, then the scissor locks in close to the wall pretty tight.
Old 11-25-2014, 09:25 PM   #17
Happy Campers
Denny and Suni's Avatar
Tv bracket
The scissor bracket and wall plate are supplied to Forest River by RAMCO Engineering in Elkhart, IN.
When ordering the scissor mount, the wall bracket and VESA plate are included. The price without shipping was around $100.00.
Denny and Suni is offline   Reply With Quote
25ds, exterior, mount, tv mount
