Micro Monitor Sensor Issue?
I have a 2014 Crusader 295RST and have noticed what I think is an issue with our Micro Monitor tank level indicator.
Each time I check the level in the black tank I get 3 LED's lit indicating 2/3 full. Then the top one goes out after a few seconds to show 1/3 full.
This happens every time I check the level even after emptying the tank. All my other sensors seem to be ok - grey, galley, fresh water, battery.
BTW I have also flushed out the tank, just in case there was any residue that would give a false reading, but it still does the same.
Anyone out there had a similar issue and what was the cause/solution?
