Old 07-07-2019, 08:59 PM   #1
Camper
microwave/fireplace not working 2019 GW 26DBH
Ive looked for a solution for this problem but none of the threads actually posted a solution. I have a 2019 Grey Wolf 26DBH. while out camping this weekend we noticed the microwave is not working, so we checked to see if anything else was not and found the fireplace wasn't working as well. Reading in here we learned they are on the same breaker so we tested it(with voltage meter) and the breaker is function properly. I should note they don't work on inverter or shore power, just nothing. Some have said there is a hidden switch but we cant find one in the posted places or any other places anywhere. Has anyone actually found a solution to this problem as it seems Im not alone. Thanx
kirbby9 is offline   Reply With Quote
Old 07-07-2019, 10:32 PM   #2
A32Deuce's Avatar
I believe there is a switch to go from the fire place to the microwave. It could be in the middle position or it could be bad. That's what I have gleaned from this forum.
A32Deuce is offline   Reply With Quote
Old 07-08-2019, 11:59 AM   #3
Head Rambler
What you're describing is a load-shed device and not an actual switch.
The most common places for them to be is behind the M/W or behind the fireplace. Have you looked in both those places?
Here's what they look like.
Gotta go campin!
Old 07-08-2019, 05:15 PM   #4
Camper
I received an email back from Forest River today and they say its behind the circuit panel under the fridge. Dont think thats something I can just pull out and replace and you right its not anything that can be reset. Ill post updates..
Old 07-08-2019, 05:44 PM   #5
Charles Firth's Avatar
Lucky for me, my Windjammer has a toggle switch next to the door. Both cannot be operated at once, only one at a time. I have 30amp service. Do you have to replace the entire switch ? I thought the switch was tacky, but now I like it. At least its easy to trouble shoot... lets us know the results.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 07-08-2019, 06:51 PM   #6
Camper
yes the entire EMS (energy management switch) has to be replaced ... your switch would have been cool! auto isn't always better. now to figure out how to get it out. forest river will warranty it but my nearest dealer is 14 hrs away so looks like it up to me.
Old 07-08-2019, 10:08 PM   #7
Itís back there, I have the same rig. The whole breaker panel/box isnít difficult to remove. Just a few screws when you get the cover off. Disco from shore power 1st and Unhook the battery to be safe.
I was poking around back there installing a EMS and ran into that transfer switch.
Hurseyc is offline   Reply With Quote
Old 07-08-2019, 10:16 PM   #8
Camper
did you have to disconnect all the wires first? or just pull out the black box?
2019 Grey Wolf 26DBS
Old 07-09-2019, 09:35 AM   #9
Head Rambler
Once you have physical access to it, it's pretty easy to replace. Also it's not nearly as big as that picture makes it look.
In our RV you can pull the power panel/converter out enough to access behind it without disconnecting and wiring. There's enough slack to get it out.
Gotta go campin!
Old 07-10-2019, 02:51 AM   #10
DouglasReid's Avatar
If FR will warranty it most times you can take it to an authorized RV repair shop.
Have a local shop look at it, and get in touch with FR to have the repair authorized
Im curious, is there a "spare" space in your electrical panel where a circuit breaker could be installed?
If so Id be tempted to add an additional circuit breaker and fish the wires to either the microwave or fireplace (Fireplace probably easier Im guessing).
This would allow you to get rid of the ALS device all together.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
26dbh, fireplace, microwave
