01-07-2012, 08:14 PM
microwave/invertor problem
I bought a whirlpool corner microwave. 0.5 cu. ft. to fit a small space. It is 750 watt output, 1200 input. I installed a Cobra 1575 Invertor. Used large cable to the batteries.
The light comes on, and the turntable turns, controls work, but it will not warm anything up.
If I take the microwave in the house and plug it in, it works fine.
I took another small used microwave, and plugged it into the invertor. That one works fine. Both are 750 watt output, but the other one is too large for the space I have.
I have never heard of a microwave not working with an inverter before. LOTS are being used that way.
Anyone have any idea what is going on?
Link to the microwave: Whirlpool 0.5 cu. ft. Countertop Microwave Oven Model WMC20005YD
Thanks for any help.
01-07-2012, 11:16 PM
I looked up your inverter online and discovered that its 120v ac power output is an "modified sin" wave and not a "pure sin" wave. The power curve of a modified isn't as clean as a pure one. Newer electronics and this does include microwaves need the cleaner source of power run properly. I had the same issue in my trailer. The inverter works good on simple devices like a toaster. But as soon as you hook up something like flat-screen TVs or newer microwaves. Hope this helps.
Stephen Georgy
2011 Lacrosse 318BHS
2006 F-350
[SIGPIC]
01-08-2012, 07:54 AM
Times two.
However stand by for "sticker shock" when you price a 2KW Pure Sine Wave inverter.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
01-08-2012, 10:01 AM
How "large" a cable, and how far a run between the battery and the inverter? Also, how many amp-hours of battery?
About the only thing that my set-up won't do, as elaborate as it is, is extended (more than a minute or two) use of the microwave. My cables are only 5' long, 1/0 (#0) cable. My deficiency is not having enough battery. I currently only have a pair of 6v golfcart batteries, giving me 220Ah of capacity. I'm considering doubling this, with a second pair, before my next boondock trip.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
01-08-2012, 02:00 PM
This inverter DOES run another microwave. And LOTS of invertors, the cheap ones, run microwaves in over the road semis. I know, I have several. And know of lots that do.
01-08-2012, 02:33 PM
The issue with the modified sine wave is very true. The newer microwaves have become more electronically complicated. I'll try to write this without getting to technical. A circuit board ultimately operates on DC voltage. Even though you plug that "wall-wart" into the wall, there is a box on the cord, or the converter is built into the device, the circuit board is working on DC. Now, the inverter is taking a DC voltage from the battery, creating a modified sine wave, which is usually a square wave or close to it, thus changing the RMS (root mean square) voltage and it comes out as "dirty power". The devices converter (aka power supply) can't clean that dirty power and properly convert it back to DC voltage for use by the circuit board. I hope that makes sense?
In previous applications you stated, there are many questions that need to be answered before an explanation of why the microwave's worked in other similar situations. 1. how the microwave circuitry to made, and protection from low or dirty power. 2. Type of inverter used, pure sine wave or modified sine wave (in my work vehicle I will only have a pure sign wave in inverter (I am an electronics/ communications technician). 3. Peak/ surge power from the inverter (may 2000 watts, but that is 2000 watts peak (for a few micro seconds) but run may be 1250 watts. 4. I am not well versed in the outfitting of tractor trailer trucks, but I do know that there are lines of specialized equipment for home type appliances in the trucks. Why aren't they used in our RV's? Cost! Looking at the cost of some of these devices would drive the selling price of the camper up.
I don't think there are to many people that can truly answer the question you have asked without physically coming to your RV with an oscilloscope, a DVM, and maybe some other test equipment and test all parts of the system.
One other thing that came to mind. Check by putting a DVM (digital volt meter) with a HOLD function and connect it to the battery. Set it to monitor LOW. Turn on the microwave. After the microwave stops, turn it off and check the DVM reading. Repeat the same steps but connect the DVM at the connections to your inverter. Record the results. If you have a reading below 11.8VDC, than that very well may be your problem. If it happens at the battery, you need to address it there. If it happens at the inverter and not the battery, then you need to look at the wire is to small for the length run, don't have large enough connections. There should also be no splices in the cables from the battery to the inverter. Also, check your in line fuse on the cable from the battery to the inverter making sure the connections are clean and tight.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
01-08-2012, 05:18 PM
Trying to cook with battery power is tough.
I know someone posted that semis do this. Semis have HUGE alternators!!
Just basic math for power looks like this--
You say your MW needs 1200 watts to run.
If you want to draw 1200 watts out of a 12 volt battery (or 2- 6 volts) you
need 100 amps. That's HUGE. Even basic battery jumpers won't normally
handle that much. Your problem might be "modified sine wave" but I'd bet
even money it's just simply not enough juice to the inverter.
(Plus the inverter is going to waste some power so you probably need more
like 120 AMPS from the battery to get the job done.)
Consider a honda 2000 or some other 2k generator.
That's a lotta cash just to warm supper.
We use stove top percolator and LP oven and stove and get by pretty
good on those boondocking trips without the MW.
My 2¢
Peace!
Dan & Rita D
01-08-2012, 06:48 PM
If the controls and display are working properly, that would indicate
that the microprocessor is executing it's code correctly. This is a
light - low current - load.
You indicate "no heating" which sounds like the magnetron - a heavy
load - is not firing. This might be due to the "non pure sine wave"
from the inverter or it might not be. If it was me, I'd gather a bit
more info. If you use a voltmeter (analog type would be best) to
check both the DC input to the inverter AT THE INPUT TERMINALS
and the AC output under load (when you press the START button).
You may find the voltage falling under the heavy load of trying to
fire the magnetron.......
If the DC is falling, check those cables. 1200 watts AC input is about
10 amps or about 100amps at 12VDC. Every 100th of an ohm resistance
in the 12VDC circuit would cause a 1 volt drop. Those large cables
need to be VERY large with very low resistance connectors.
And, of course, the battery needs to be able to supply that current
with minimal voltage drop; many inverters shut down when the input
is below about 10 volts..................
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
01-09-2012, 09:30 AM
It powers another microwave of the same size just fine, so I think all the talk of cable sizing, batteries, etc. is moot.
It is ONLY this one specific microwave that does not work. I have LARGER microwaves in other semis that work fine.
I have 4 large 12 volt batteries and a 180 amp alternator in the truck, so that is not a problem. I am only talking about a 2-3 minute run to warm up lunch in the truck, not cooking a 18 lb turkey for two hours!
I believe it is specific to this mag on this microwave.
MP
01-09-2012, 10:05 AM
MP
You may well be correct - it may be time to find a replacement
that works for you.
......But it never hurts to check rather than assume......
As the pilots say: "In God, we trust. All else, we check."
[Right Lou??]
cheers,
johnd
01-09-2012, 03:52 PM
MP
Sounds like another microwave is in order.
And if you'd told us the above first we wouldn't have preached so much
on the wire size and amps needed to do the job
Peace!
Dan & Rita D
01-09-2012, 04:36 PM
He did say in the original post that another oven of the same
power worked with his inverter. That does seem to indicate that
the problem is with that model, or maybe that specific unit.
I suggested gathering more info because just because the label
says "same power" don't mean that two ovens would draw the
same current from the AC line. Different models can have radically
different efficiencies. And, of course, that particular unit can have
a defect that causes it to draw way more current than it should.
Plugging it into the AC mains with a 20 or 30 amp breaker could
"hide" the problem. Thus, my suggestion to find out what is really
happening.
As usual suggestions are worth what you pay for them, so he'll do
what he thinks is right for himself..................
cheers,
johnd
01-11-2012, 12:01 AM
I wish I could use another model. This one is the only one I can find that fits in the space in my Peterbilt sleeper. It has the controls and mag under the unit, instead of beside it, so it is basically a cube. Anyone that has the unit and the controls on the side is too wide to fit.
That is why I was so happy to find this unit that fits. It is the only one that is this size, or smaller.
The other microwave I tried, and that worked, has the same input watts of 1200, and the same output of 750.
The inverter shows the one that works is pulling 720 watts, but the one that does not work is not drawing any watts.
01-11-2012, 08:50 AM
You *DO* have a problem, don't you?
Probably would receive more friendly (and perhaps
useful) advice if you avoided terms like "Preaching"
and concentrated in working WITH the folks who are
trying to help........
YMMV.
cheers,
johnd
PS I would still like to thank all the helpful folks who helped
me solve a vexing problem with my TT. Never did sound
like Preaching to me! You be good folks so I'd like to "pay
it forward" whenever I'm able...................
01-11-2012, 09:01 AM
that works for you.
[Right Lou??]
cheers,
johnd
I seem to recall it was: "In God We Trust; all others pay cash."
As a former pilot I totally agree with the sentiment though.
01-11-2012, 09:10 AM
I am sure you are perfectly aware that only input watts count when powering the microwave.
What you might not be aware of is the "power up" load on the magnetron could momentarily exceed that "running" 1200 watts. If the mag in your new microwave exceeds the peak watts on your inverter (usually the max watts printed on it), it will "turn off" and output zero watts. The amount of peak draw varies by magnetron manufacturer and a larger inverter may solve your problem (IMO).
01-12-2012, 08:48 AM
It might. The 1500w output is continuous, it has a 3000 watt surge.
I know about the input. That is why I compared the one that works, and the one that does not. They both have labels with 1200 watt input.
01-12-2012, 08:52 AM
YMMV.
cheers,
johnd
I did NOT use that term. It was used by another poster in reference to ANOTHER reply. I am very appreciatative of help.
01-12-2012, 09:00 AM
Then we keep coming back to the wave form. Apparently the modified sine inverter is not working for you. a 2000 watt, 3000 watt peak, pure sine inverter has a price that will open your eyes.
Go Power! GP-SW2000 12v 2000 Watt Pure Sine Wave Inverter
01-12-2012, 09:06 AM
I thought of something else. (cheaper maybe).
The simplest solution...
Do you have a battery volt meter that you can see when you run the microwave?
If so, what is your battery voltage when the new microwave fires up?
Does the voltage dip momentarily below 11 volts? The fact that it bounces right back up again is meaningless to the inverter. Once it hits the low voltage cut out the only way to get it back on line is to reset it.
There might be a beep or tone when the inverter shuts down.
Try it with the engine running. That "might" solve your problem and you won't need to buy a new inverter.
