03-17-2018, 09:42 AM
Microwave just a timer?
First trip in new trailer. Microwave appears to turn on with panel counting down but nothing happening inside. Turntable not turning. Fan not fanning. Cooker not cooking. Reset breaker. No joy. Any ideas? Thanks!
Brian and Tracy
2017 Flagstaff 26FKWS
2019 GMC Sierra 2500 Denali
6.0 Gasser 4:10
03-17-2018, 09:50 AM
A picture or brand name and Number would help. It is no different than your home MW. It does, in fact, have just a timer function. It also operates as a Microwave. There is probably about 6 programmed times. Push one and it will go. There is also a timed cook button. Push it then add your desired time then push cook. (Or some form of that explanation). Ask the DW or DGF
03-17-2018, 09:53 AM
We have tried all of those things with same result. Tried manual time, programmed time. Nada.....
Brian and Tracy
6.0 Gasser 4:10
03-17-2018, 10:50 AM
Looks like it's time to visit the dealer.
Did you reference the owners manual? perhaps a FAQ page?
03-17-2018, 11:36 AM
Just as confused as you
Some MW's can be used as a timer only. You need to supply the Manufacturers name and model number so we can help, this info can be found on the inside of the door frame. A picture of the control panel can help too.
Richard & Jill
03-17-2018, 11:53 AM
This happened to ours as well. I solved the issue. Turn your microwave on and apply a bit of pressure on the top of right side of the door. If it starts working, the metal hinge on the inside of the door (right side) needs to be bent slightly. The metal piece is not contacting the inside of the microwave to “turn on” (edited)
03-17-2018, 12:06 PM
We had this happen once, if the door trick doesn't work, check your power at the plug the microwave plugs into, could be low voltage there. We had the low voltage, it was a bad plug.
03-17-2018, 12:14 PM
I agree. If the frame behind the door has a hole with a metal tab then the protrusion on the door is not pushing enough on the microswitch inside that hole. The same can happen if the MW has a plunger type switch.
Richard & Jill
That did it!
Nailed it! Thank you very much. Sending a virtual beer your way!
Brian and Tracy
6.0 Gasser 4:10
03-17-2018, 12:28 PM
Awesome!!! Glad to hear it! Thanks for the beer.
03-17-2018, 12:30 PM
Chalk up another one for the Forest River Forums!
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
03-17-2018, 02:56 PM
Wow, good call emjayuu.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
03-17-2018, 07:27 PM
Dobbs from WI
And I thought for sure he didn't have the propane turned on...
I'll take a tequila, please.
03-17-2018, 08:35 PM
You bad.
