Old 05-01-2016, 02:57 PM   #1
microwave oven
I have a magic chef modelmco2212arw over the range microwave that went bad. where can I get a replacement? the rough opening it goes in is 25&3/4 inches wide with cabinets on both sides. it is in a 2003 cardinal 5th wheel rv. thank you for any help.
skipper194242 is offline   Reply With Quote
Old 05-01-2016, 03:04 PM   #2
raspivey's Avatar
You might have trouble finding that exact model. Are you trying to find an exact replacement? As long as the dimensions are the same, any make / model should work.
Old 05-02-2016, 09:31 AM   #3
microwave oven
I was not concerned about the same model but my demensions are restricted to 25 inch width due to food pantry one side and cabinets the other my old microwave was 22 inches wide. all the over the range microwaves I found require a 30 inch opening.
Old 05-05-2016, 05:09 AM   #4
Cajun Style's Avatar
I found one at Walmart made by Hamilton beach.
Harry-O
Cajun Style is offline   Reply With Quote
Old 05-05-2016, 05:12 AM   #5
I had to change my microwave Monday it arced off around the door seal, DW thought I was BBQing outside, it was her and the microwave.
From what you have described it might be the arm bracket detached it self or was never connected.
I unplugged the microwave then removed the screws that hold the bracket around the microwave and slowly and carefully removed it out of the hole.
It should not be hard to repair.
I went to wal-mart and found a microwave close to the same size HB 0.9 cu. ft. It had some red on it so DW like the upgrade in color.
I had to find the right bits for the screws that hold the bracket arms to the microwave it's a star with a hole in it, then there are some feet that are on the bottom that need to come off.
Now on the new microwave you have to drill some holes for the feet to be screwed back in do not over tighten it will strip the hole. I found some new screws for securing the brackets to the microwave, I adjusted the brackets to fit the front of the microwave Sotheby's door opens correctly then I drilled some holes and put the new screws, then I put the microwave in the edge of the hole and ran the electric cord in the hole to the receptacle slid the microwave the rest of the way and the holes for the bracket matched up perfect.
I made sure all the tape was all taken off and it worked as advertised.
Harry-O
Harry-O
Old 05-05-2016, 06:34 AM   #6
Harry-O
Harry-O
Do you have pics?
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 05-05-2016, 08:58 AM   #7
Sure don't.
Harry-O
