Old 03-29-2013, 09:05 PM   #1
Microwave Problem
I have a 2006 Salem 27BHSS with a Magic Chef microwave. Today I tested it for the first time and was unable to get it to run unless I held the door in a certain way and pushed start. I don't know if it is a door issue or the start button because sometimes I had to hold the start button or it would shut off. Is there a way to adjust the door? The trailer is not sitting level, would this cause a door issue?
Woolaroc is offline   Reply With Quote
Old 03-29-2013, 09:16 PM   #2
Iggy's Avatar
To fix you will have to remove from mount and open up the case and readjust the micro switch in the door so it can activates the system.
Iggy is online now   Reply With Quote
Old 03-29-2013, 10:14 PM   #3
Thanks I'll give that a shot. Does the micro switch adjust easily?
Old 03-29-2013, 10:35 PM   #4
Iggy's Avatar
I can't be sure about yours but it usually has a small platic part that hits the latch to active all the rest.
Here is a link to a video on how it woirks and how to repair.
Microwave Two Terminal Switch Testing - YouTube
Here is another
http://youtu.be/NhlS6WmN7T4
Hope it helps
Old 03-30-2013, 09:47 PM   #5
Thanks Iggy!
