Old 04-27-2019, 09:47 AM   #1
Rangie's Avatar
Microwave Replacement
I’m needing to replace the microwave in our 2011 Flagstaff. It did not have one in the unit when we bought it.
Does anyone know what size we need and can we just pick one up somewhere like Wal Mart or Target?
Rangie is offline   Reply With Quote
Old 04-27-2019, 10:32 AM   #2
I'm guessing you bought used and the micro was removed Measure the hole and go to Walmart or Target. Nothing special about RV's. You will need to install the mounting bracket on the back wall and drill two holes in the bottom of the upper cabinet. And run a 15/20 amp circuit if you don't have one.
Old 04-27-2019, 10:38 AM   #3
Rangie's Avatar
There is already an outlet in the box and like a metal surround set up.
Is there a certain cubic foot that is supposed to go in there?
Old 04-27-2019, 11:29 AM   #4
Measure the opening top to bottom and front to back. Get new microwave to fit the opening.
Travelin Buzz is offline   Reply With Quote
Old 04-27-2019, 11:47 AM   #5
Whatever will fit. The metal surround sounds like a trim piece. Doesn't need to be there.
Old 05-02-2019, 11:01 PM   #6
Rangie's Avatar
Ok, thanks.
Old 05-03-2019, 10:57 PM   #7
Retired Old Fart
dward51's Avatar
Also while at Walmart or Target, pickup a thick pool noodle. You want to cut a section to used as a wedge to keep the glass turntable inside your new microwave from bouncing around and breaking while driving down the road.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
dward51 is offline   Reply With Quote
microwave, replacement
