Old 03-23-2012, 09:20 AM   #1
microwave stopped cooking
recently purchased a used 2011 surveyor 189 with a hamilton beach 900 w mircowave. everything works but it does'nt cook. most likely the wave guide is shot. looking to get a replacement, has to be a fit in 20.5x14.5x14 any help leading me in the right direction would be great.
Dick & Betty
2016 Chevy Silverado 1500 crew cab
2017 Grey Wolf 23mk
vp22er is offline   Reply With Quote
Old 03-23-2012, 09:42 AM   #2
Oakman's Avatar
Is the microwave still under warranty? If so I'd have the dealer replace it.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-23-2012, 09:44 AM   #3
bikendan's Avatar
if it's not under warranty, as far as i know, any household MW will work.
as long as it fits in the cabinet.
there's no special "RV" microwave, since it still is regular 110v AC.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-23-2012, 09:49 AM   #4
no, it's not under warranty, and the service dept basically said it would be a whole lot cheaper if you did it yourself.
Dick & Betty
2017 Grey Wolf 23mk
Old 03-23-2012, 10:49 AM   #5
acadianbob's Avatar
Yes, and if you can find the right size, it will be easy enough. You will find a 110 outlet back there that it just plugs into.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-23-2012, 10:58 AM   #6
punkaccountant's Avatar
Whenever we are connected to shore power with the 30 amp to 15 amp adapter, the microwave will run but not cook very well. Once we connect back to 30 amp, though, it works fine. Could this be the problem?
punkaccountant is offline   Reply With Quote
Old 03-23-2012, 11:31 AM   #7
Great Horned Owl's Avatar
If the microwave is plugged into a duplex outlet, connect a digital voltmeter to the other outlet and check the voltage while the microwave is running. If it drops below 110V you either have a bad adapter, or you are connecting to a bad 15 amp circuit.
If it is not at a duplex outlet, connect it through one of those outlet extenders.
Great Horned Owl is offline   Reply With Quote
Old 03-23-2012, 12:31 PM   #8
no on the duplex. I pulled the unit and tried it in the house, still does'nt cook. Looking for a replacement that will fit the adapter 19x10.5x 14 to 15.
Dick & Betty
2017 Grey Wolf 23mk
Old 03-23-2012, 01:43 PM   #9
Herk7769's Avatar
The magnetrons in most microwaves are warranted for 10 years. They are limited to the free replacement of the part ONLY; not the labor to install.
If you have experience with servicing TEMPEST computers (I do) or microwave equipment you should have no trouble changing out the magnetron. If you do not know how to service a machine that generates microwaves you should leave this repair to a professional.
If the metal foam seals around the magnetron are not properly maintained, microwave radiation can leak out into the camper causing all kinds of havoc to equipment and people.
HAM CALLSIGN - KC3FFW
Old 03-23-2012, 02:21 PM   #10
FYI - Dometic microwave, supposedly designed for RV's, is approx $150.00 at Camping World.
...VTX-Al
VTX Al is offline   Reply With Quote
