Old 11-18-2013, 09:41 PM   #1
Iwannacamp's Avatar
More heater problems...
I have a Puma 295kbh 2011 model 5th wheel. My heater doesn't work. It will make a small click several seconds after you call for heat..nothing else. I have good gas to the stove(right above). New propane refill. I pulled the cabinet front and checked the temp overload on the front. It has over 12.5 volts. I checked the connections (wiggled while on) nothing. I took the gas line loose and two front screws out.. But it won't come out...it wiggles, but I don't wanna pull to hard. I don't see anything but the 4 screws on the outside. I didn't wanna take this off and disturb my water seal unless needed. What is the next step. It is a a Suburban 30 series
It looks near new in there.
Ps: I reached back there and turned the motor. It is not blocked or seized.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-18-2013, 11:00 PM   #2
Dave_Monica's Avatar
Do I understand correctly that the furnace fan isn't running? If the fan is free to turn, it must be a loose electrical connection somewhere in the fan circuit.
Here's a link to the Surburban Furnace trouble-shooting guide from the library section of the forum... Forest River Forums - Downloads - Furnace - Suburban furnace troubleshooting
Dave
Old 11-18-2013, 11:21 PM   #3
Iwannacamp's Avatar
No sir. Nothing is doing anything. I get a small "click" after you turn the heat on... Then nothing. I read on the internet that the screws on the outside have to come out... I was hoping that wasn't needed. I guess that's for the morrow.
Thank you. I will keep the updates posted unless someone "fixes" this before then.
2017 Puma 297RLSS
Old 11-20-2013, 08:31 PM   #4
Iwannacamp's Avatar
Tadaaaaa!! Heater fixed. I had a hard time getting it out...scared I would break something I couldn't eat. The intake pipe is plastic and I guess sand and what not was causing it to stick. Finally got that out and discovered a bad connection somewhere. I "bench tested" while still wired up and it worked. Rewired the crappy connections they had and extended the wires. Still worked...so I reinstalled and it still worked. Life is good. Thank you God and those who helped along with the forum and the internet. Total cost .50 wire and connectors from the house.
2017 Puma 297RLSS
