What is behind the wall where the sticker is that says you can mount the TV? I will be taking possession of a Palomino Puma 31FKRK in a couple weeks and wanted to put a TV in the bedroom.
For those thats done that is the sticker in the exact place or just close to it. I've seen some videos where folks use a stud finder and wonder if I should go ahead and get one.
more they likely there is a piece of plywood in the wall where the sticker is. Just a helpful guide and a reinforced area to mount your bracket. You could still try and find a stud if desired.
I used a stud finder and found the plywood backing wasn't centered with the sticker, but the off center backing worked out because the adjustable mount needs to be off center to fold back against the wall when the telly isn't out for viewing.
